on 21-05-2021 17:18
Hi, last week we put our superhub into modem mode and added an asus ax86u router. All worked well for a few days. Much improved connection. So fast. But now we seem to have issues. Speed is reduced again and yesterday we lost connection totally. I have rebooted the router. Im a bit of a novice and trying to do all this with lack of knowledge! My son has severe learning difficulties and i need a stable connection so he can watch his youtube videos.
Is there anything i should be doing to make this work better. We seem to have gone back to the issues we had with our superhub regarding service. I have a think broadband monitor set up since we added the asus. I had one on the virgin router too but that went solid red once the new router was added. Funnily enough that started showing stats again the last few days, didnt think it would. I have disabled that one now.
Any help would be gratefully received for someone who is clueless on how to sort this. Many thanks
Answered! Go to Answer
on 21-05-2021 20:27
Thank you. As soon as my son is in bed and i can take the wifi off i will try that
on 21-05-2021 21:53
Have turned it off and switched back on. Do the pre rs errors need to be 0 too? Downstream bonded channels
1 | Locked | 38.6 | 4 | 0 |
2 | Locked | 38.6 | 1 | 0 |
3 | Locked | 38.9 | 0 | 0 |
4 | Locked | 38.9 | 0 | 0 |
5 | Locked | 38.6 | 0 | 0 |
6 | Locked | 38.6 | 0 | 0 |
7 | Locked | 38.6 | 0 | 0 |
8 | Locked | 38.6 | 6 | 0 |
9 | Locked | 38.6 | 0 | 0 |
10 | Locked | 38.6 | 8 | 0 |
11 | Locked | 38.9 | 14 | 0 |
12 | Locked | 38.9 | 6 | 0 |
13 | Locked | 38.6 | 5 | 0 |
14 | Locked | 38.6 | 0 | 0 |
15 | Locked | 38.9 | 0 | 0 |
16 | Locked | 38.9 | 4 | 0 |
17 | Locked | 38.9 | 5 | 0 |
18 | Locked | 38.9 | 0 | 0 |
19 | Locked | 38.9 | 0 | 0 |
20 | Locked | 40.3 | 5 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 40.3 | 5 | 0 |
24 | Locked | 39.3 | 3 | 0 |
on 21-05-2021 21:56
pre-rs aren't really a problem.. they indicate errors that the hub was able to correct.. it's the post-rs errors that you need to worry about.. which indicate errors that the hub was unable to correct.
on 21-05-2021 22:01
Thank you for the explanation. I am a real novice at this! I will keep checking to see what they do and post back tomorrow for advice. Appreciate everyone's help. My son has no understanding if we have no wifi!
on 22-05-2021 00:25
on 22-05-2021 02:39
hi i was just wondering i keep getting post rs errors on some channels, what is the expected errors normally or should it not be doing any? and t3 time outs too that seems to happen. any advice on keeping these errors down?
on 22-05-2021 06:31
@mus1991 wrote:hi i was just wondering i keep getting post rs errors on some channels, what is the expected errors normally or should it not be doing any? and t3 time outs too that seems to happen. any advice on keeping these errors down?
It’s best to start your own thread with the detail of the problem and provide the information from the hub that was requested in this thread.
on 22-05-2021 11:38
Ive checked this morning and they are still at 0 but the pre rs numbers have gone up. Last night the v6 box wouldnt connect to what we were watching on prime later on in the night. It does that most nights now. It was fine to start with.
Do you need to see all stats again? We have always had issues with our connection despite many many calls to virgin. Connecting the asus worked amazingly for a few days only. Its still faster than before but maybe ive done something wrong?
The 5g connection seems to keep going off. My sons ipad was on it and then it kept asking for the password but telling me it was incorrect. I connected him to the 2.4 one fine. It doesnt automatically come up on the network list either. The v6 boxes are on the 2.4 one as the 5g one had a worse signal.
on 22-05-2021 14:50
These have appeared though
22/05/2021 12:26:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:26:33 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:22:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:22:45 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:22:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:22:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:21:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:21:31 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:20:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:19:57 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:19:33 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:19:32 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:19:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:19:5 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:45 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:26 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/05/2021 12:18:11 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 22-05-2021 15:43
