on 24-08-2022 00:26
Currently on Volt Gig1 (with 52 Mbps upstream).
Since early on Monday morning (2022-08-21), I have been experiencing regular internet disconnects at appx. half-hourly intervals.
These last from a couple of seconds to appx 30 seconds.
I didn’t notice this until late Monday night when attempting to play online gaming.
I only have PC, printer and one V6 box connected via ethernet and another V6 box and mobile connected via wi-fi, so nothing too strenuous.
I have rebooted my PC, Hub4 (3x) and performed a hard reset on the Hub4 (3x).
Aside from that I I have also checked the head-end, all coax connections etc.
The first time I performed a hard reset, it actually triggered a software update which I thought might solve the problem, but no.
When I check the online service status it doesn’t find a fault in my area, but further checking the broadband, it states:
“Looks like there's still an issue with your connection
We're looking into it. Check back here after * hours and if there's still an issue we'll help you book a technician.”
* Currently at 3 hours.
The Hub4 diagnostic tool reports:
1 Your broadband connection is working.
2 Gateway IPv4 address is valid.
3 Your broadband connection is ready.
4 The temperature of your Hub 4 is normal.
5 There is no telephone service.
Tue Aug 23 15:21:34 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 15:21:40 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 15:21:56 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 17:13:12 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 17:42:58 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 18:13:49 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 18:13:57 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 18:47:40 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 19:17:00 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 20:38:53 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 20:38:58 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 20:39:08 2022 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 20:39:08 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 20:48:32 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 21:11:00 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 22:16:12 2022 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Aug 23 22:46:05 2022 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 15-04-2023 21:01
Had text message from VM about outage on BB, TV & Voice fault F010597427.
Latest fix estimate is 19th April @ 18:00.
We'll see.
Current BQM isn't too bad:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/501a243cb089ea47099aa98f000f038e99...
17-04-2023 18:53 - edited 17-04-2023 19:16
I've have what appears to be a very similar scenario to the one you describe going on since the end of 2022 / early 2023.
Since the end of 2022 year I've had short disconnects (normally under 10-15 seconds) every 30 / 60 mins. I'm on a 1GB connection and a Hub 4 since last July. I've been with Virgin about 10 years and had a fantastic connection until this year.
I ignored it for a while but it is really disruptive of online games and video calls so early March I installed software to track the connection.
The connection always drops at the same time e.g. yesterday and today it is dropping at 36 mins past the hour.
It doesn't always drop every hour - but if it is going to drop it will drop in those time windows.
Today (17th April) the connection dropped at 36 mins past the hour most hours:
01:36
02:36
04:36
05:36
10:36
11:36
12:36
13:36
14:36
15:36
17:36
Yesterday the time drifted a little throughout the day:
23:36
22:36
16:33
13:32
10:30
05:28
00:25
The above disconnects come from my internal monitoring software that are less sensitive that the BQM monitors - here is today from BQM and you can see the red disconnects every 30 mins:
17th April:
another chart from 14th March:
I've had two engineer visits who have replaced the splitter and removed an attenuator. They also changed my port in the local cabinet. It's now been escalated to the networks team - but hasn't led anywhere yet. They have confirmed they are seeing 400 - 500 disconnections a week.
I had a brief window from 11-13 April where I had no disconnections - but after that 2 day break am back to regular disconnections.
Virgin are apparently going to try a Hub 5 to see if it makes any difference. After putting up with this for several months I'm going to give up on Virgin if the Hub 5 doesn't work.
on 17-04-2023 19:11
Posting Hub4 configuration / log in case that helps someone:
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Online | DOCSIS 3.1 | |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 17-04-2023 19:12
Downstream
4 | 163000000 | 7.5 | 39 | QAM256 | 4 |
1 | 139000000 | 8.2 | 39 | QAM256 | 1 |
2 | 147000000 | 8 | 39 | QAM256 | 2 |
3 | 155000000 | 7.9 | 39 | QAM256 | 3 |
5 | 171000000 | 7.3 | 38.6 | QAM256 | 5 |
6 | 179000000 | 7 | 39 | QAM256 | 6 |
7 | 187000000 | 6.7 | 40.4 | QAM256 | 7 |
8 | 195000000 | 6.3 | 39 | QAM256 | 8 |
9 | 203000000 | 5.8 | 39 | QAM256 | 9 |
10 | 211000000 | 5.4 | 39 | QAM256 | 10 |
11 | 219000000 | 4.8 | 39 | QAM256 | 11 |
12 | 227000000 | 4.8 | 39 | QAM256 | 12 |
13 | 235000000 | 5 | 39 | QAM256 | 13 |
14 | 243000000 | 4.8 | 39 | QAM256 | 14 |
15 | 251000000 | 4.2 | 39 | QAM256 | 15 |
16 | 259000000 | 4.4 | 38.6 | QAM256 | 16 |
17 | 267000000 | 4.8 | 38.6 | QAM256 | 17 |
18 | 275000000 | 5.3 | 39 | QAM256 | 18 |
19 | 283000000 | 5.2 | 39 | QAM256 | 19 |
20 | 291000000 | 5 | 39 | QAM256 | 20 |
21 | 299000000 | 4.9 | 38.6 | QAM256 | 21 |
22 | 307000000 | 5.3 | 39 | QAM256 | 22 |
23 | 315000000 | 5.7 | 40.4 | QAM256 | 23 |
24 | 323000000 | 5 | 40.4 | QAM256 | 24 |
25 | 331000000 | 4.6 | 40.4 | QAM256 | 25 |
26 | 339000000 | 4.4 | 40.4 | QAM256 | 26 |
27 | 347000000 | 4.3 | 39 | QAM256 | 27 |
28 | 355000000 | 4.2 | 40.4 | QAM256 | 28 |
29 | 363000000 | 3.9 | 39 | QAM256 | 29 |
30 | 371000000 | 4 | 38.6 | QAM256 | 30 |
31 | 379000000 | 3 | 39 | QAM256 | 31 |
4 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
5 | Locked | 38.605377 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.605377 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1840 | QAM4096 | 759 |
159 | Locked | 40 | -2.3 | 1749298359 | 0 |
on 17-04-2023 19:12
Upstream
1 | 36600000 | 36.5 | 5120 KSym/sec | QAM64 | 3 |
2 | 23600000 | 35.5 | 5120 KSym/sec | QAM64 | 5 |
3 | 30100000 | 36.5 | 5120 KSym/sec | QAM64 | 4 |
4 | 43100000 | 37 | 5120 KSym/sec | QAM64 | 2 |
5 | 49600000 | 37.8 | 5120 KSym/sec | QAM64 | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
6 | 10.0 | 30.5 | 2K | QAM128 |
6 | OFDMA | 200 | 53.9 | 2 | 0 |
on 17-04-2023 19:14
Network log
Mon 17/04/2023 13:06:45 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 12:52:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 12:00:31 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 12:00:31 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 10:06:35 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 08:37:35 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 08:36:23 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 17/04/2023 07:11:12 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 20:35:48 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 20:08:26 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 14:32:56 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 13:55:02 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 08:29:55 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 06:37:24 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 03:28:10 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/04/2023 03:27:44 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 19:25:01 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 18:42:12 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 10:48:30 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 10:45:35 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 06:57:12 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 15/04/2023 05:04:44 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 14/04/2023 18:16:26 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 14/04/2023 18:16:26 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 14/04/2023 18:16:10 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 13/04/2023 19:40:25 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 13/04/2023 14:46:01 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 13/04/2023 14:41:50 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 13/04/2023 14:41:49 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 13/04/2023 02:58:14 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 12/04/2023 20:17:17 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 12/04/2023 14:51:25 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 12/04/2023 13:03:33 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 11/04/2023 00:51:46 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 12:39:05 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 12:39:05 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 12:38:47 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 10:58:08 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 10:37:28 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 10:20:13 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 09:32:35 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 10/04/2023 03:15:03 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 19-04-2023 20:05
Thanks for coming back to us reidm99, how has your connection been running since you last posted on Monday? I have looked into your connection on our systems and cannot see anything that would be causing your issues.
Kind Regards,
Steven_L
on 20-04-2023 02:43
Hi Steven, connexion has been stable, although there was a Fault registered: Service update. Broadband, Voice and TV fault F010597427 which was due to be fixed by 18:00 Tuesday 2023-04-19.
I haven't seen any major issues regarding this- see BQM & network log - but the status line [0800 561 0061] is still reporting a 'complex issue' in my postcode @ 2023-04-20 02:38.
I therefore will continue to monitor as long as that is the case.
18-04-2023 13:34:46 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 13:34:46 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 12:28:36 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 12:28:36 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 04:29:41 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 04:29:41 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 03:27:27 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-04-2023 03:27:27 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 20:25:39 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 19:35:44 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 19:35:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 18:55:21 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 18:55:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 16:34:09 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 16:34:09 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 15:27:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 15:27:54 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 12:31:57 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 12:31:57 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 11:26:45 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 11:26:45 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 03:57:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 03:57:44 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 03:47:39 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-04-2023 03:47:39 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 19:53:54 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 19:53:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 18:53:19 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 18:53:19 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 18:02:53 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 18:02:53 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
16-04-2023 16:57:52 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 22-04-2023 09:41
Hi @reidm99,
Thank you for expanding on this and providing that fault reference number too. I've checked over it, and it appears that fault has now been resolved. Can you confirm if your issues are ongoing today?
on 22-04-2023 11:12
Hi Zach,
The status line is no longer reporting a fault in my area and I haven't seen any disconnects or packet loss for sometime.
I will consider this closed now, but will still keep an active BQM in case any issues crop up.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/501a243cb089ea47099aa98f000f038e99d64ed9
