on 12-03-2023 09:35
Hi, I have a red light solid on my hub3 since last yesterday, but connection is ok no issues so far. WiFi is ok and lan is ok. From white it turned to yellow,orange and now red
Reading other threads I am pretty sure I need a replacement as the Led circuitry has an anomaly, but I was wandering if I can ask for the new Hub5, as the upgrade is needed. If yes what to do ?
Thanks in advance
on 06-04-2023 09:31
Hi ergo1999,
Thank you for reaching out to us in our community and welcome back, 👋 Sincerest apologies for any frustration or inconvenience caused by the outage! Hopefully everything is sorted for you now? 🤞 Thank you for your patience with us! Hope you have a lovely day. 🌞
Paul.
on 06-04-2023 09:48
Issue is not sorted yet as although wifi and cable are working I have a constant red light.
Tried to reset many times but still red.
Can you pls replace my modem ?
Thank you
on 06-04-2023 17:16
i have tried to reset the modem, as you recommended, but still the same.
I have posed my situation but no solving answers.
could you help me pls
light is always red fix, but internet is working fine
thank you
on 10-04-2023 12:04
Hi @ergo1999,
Thank you for popping back 🌞
I am so sorry to hear you still have this redlight and we will get this replaced asap, I will pop you over a PM so I can get some details to book this in for you, just keep an eye out for the little envelope 📩
Zoie
on 10-04-2023 14:14
