on 03-12-2022 12:39
Have had my Hub3 for at least 5 years and yesterday I noticed power light was red. Checked status of area but was okay so requested connection check which came back as intermittent fault.
Turned off hub during night to make sure hub was cold when switched back on this morning. Still red light showing but connection check stated to do reboot of hub. Which I did but no difference.
Strangely my internet connection remains and so does my Wi-Fi. Usually when red light is showing my internet connection is down.
Does my hub need to be replaced?
Your advice would be welcomed.
Answered! Go to Answer
on 03-12-2022 12:44
Usually due to the age of the hub the white led light will fail. My advise would to contact customer service so they can run some tests intermitted issue usual last no longer than 24 hrs if the snr issue in the area can take longer. Also to check if the hub is hot to touch but to be fair the agents can do tests to see of there is a performance issue
on 03-12-2022 12:44
on 05-12-2022 18:21
Hello thomas93,
Thanks for your post.
Sorry to hear about the red-light on the hub.
We will need to arrange for a service technician to attend and swap this over.
In the mean time, Can you please ensure its upright in a well ventilated place and away from any direct source of heat.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
