on 30-07-2022 09:00
since having my hub. 4 router changed the pods will not sync to it. The white light on the pod is still flashing after being on overnight even though the guy at Virgin centre yesterday assured me it would happen in much less than 15 minutes “I promise “ he said. Any ideas?
Answered! Go to Answer
on 01-08-2022 21:16
just make sure that your 2.4 and 5ghz WIFI SSIDs are named differently ie:
XXXXwifi2 and XXXXwifi5
for instance, then any device such as smart plugs/lights/ring doorbells that will only work on 2.4ghz can only log onto your 2G network not try logging onto your 5G network.
on 31-07-2022 08:58
I had the same problem after the technician came and for some reason changed my settings.
I switched “channel optimisation “ to ENABLE and it worked!
the pod then logged on within five minutes
on 01-08-2022 19:18
Brilliant thank you!! They now work!! Another satisfied customer!
now, what do know about connecting smart plugs on 2.4g only?
on 01-08-2022 21:16
on 01-08-2022 22:21
Could I make my “guest” network just 2.4 for instance? The ssid used to be suffixed with 2 and 5 but no more in the hub 4. The app doesn’t really work either. (For pausing a rogue x box in the middle of the night for instance 😉
on 01-08-2022 22:43
PODS will not work correctly if the 2.4 and 5g networks have different names and the wireless channels need to be set to auto and auto optimization needs to be ticked at all times.
on 02-08-2022 05:54
I’ve tried both ways, naming both SSIDs the same and naming them differently ie one called 2G and the other called 5G and it made no difference at all.
on 02-08-2022 08:01
I really appreciate your insight into this. It looks like then Amazon wifi sockets I’ve bought over the years will not work again on this router which is odd as it was a like for like swap. (Replacing the one which was playing up)
on 04-08-2022 11:18
I discovered a fix. Taking the socket out of reach of 5g and pairing it there. Clumsy but it worked!
on 07-08-2022 10:20
Hi @Sandmwyer, thanks for posting and welcome back to our community.
Thanks for getting back to us and confirming your issue has been resolved. Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Also, please bear in mind that our website offers lots of helpful information and also, you can manage your account from here. And here, will answer many questions regarding our pods.
Lee_R
