Persistent intermittent packet loss for weeks...
andrewpieri
Hoping someone can help or point me in the right direction.
Been observing intermittent packet loss for weeks now, prior to this was very reliable no loss for months! Contacted support who arranged an engineer visit, swapped out router and some cables, but problem still persisting.
Tbh impact is not that serious, but WFH so spend most of my day on Teams call plus blips when watching movies.
Checked power levels and think all good, my guess is a network related issue rather anything to do at home. My only recollection (been a while now) and ironically started after Virgin planned network maintenance.
Any advice or help very much appreciated.
Ps
Tried factory resetting the Hub with no change. I did get a day or 2 where thought was improving, but then back to usual.
1339000000-1.340QAM 25626
21390000001.340QAM 2561
31470000000.640QAM 2562
4155000000040QAM 2563
51630000000.240QAM 2564
61710000000.440QAM 2565
71790000000.740QAM 2566
81870000000.640QAM 2567
91950000000.540QAM 2568
102030000000.440QAM 2569
112110000000.140QAM 25610
122190000000.140QAM 25611
13227000000040QAM 25612
14235000000041QAM 25613
152430000000.440QAM 25614
16251000000-140QAM 25615
17259000000-1.240QAM 25616
18267000000-1.440QAM 25617
19275000000-1.540QAM 25618
20283000000-1.440QAM 25619
21291000000-1.440QAM 25620
22299000000-1.240QAM 25621
23307000000-1.140QAM 25622
243150000000.941QAM 25623
25323000000-1.141QAM 25624
26331000000-1.241QAM 25625
27347000000-1.341QAM 25627
28355000000-1.441QAM 25628
29363000000-1.541QAM 25629
30371000000-1.741QAM 25630
31379000000-1.641QAM 25631
1Locked4000
2Locked4000
3Locked4000
4Locked4000
5Locked4000
6Locked4000
7Locked4000
8Locked4000
9Locked4000
10Locked4000
11Locked4000
12Locked4000
13Locked4000
14Locked4100
15Locked4000
16Locked4000
17Locked4000
18Locked4000
19Locked4000
20Locked4000
21Locked4000
22Locked4000
23Locked4000
24Locked4100
25Locked4100
26Locked4100
27Locked4100
28Locked4110
29Locked4100
30Locked4100
31Locked4100
04960000041.35120QAM 165
14310000042.35120QAM 166
23660000042.85120QAM 167
33010000043.55120QAM 168
42360000044.55120QAM 1611
0ATDMA0000
3ATDMA0000
4ATDMA0000
https://www.thinkbroadband.com/broadband/monitoring/quality/share/308c7af580613784213b9eb4aaf6eaae28a12c74-19-11-2022
36 REPLIES 36
Reece_MH
Hi @andrewpieri,
Thanks for your post, and welcome back to the Community Forums.
I'm sorry to hear you're having problems with your service. I've attempted to run diagnostics on my end, but have been unable to do so as your Hub is in Modem Mode.
Are you able to take your Hub out of Modem Mode for the next 24 hours, or so, so we can run full tests? Are you seeing the issue primarily on Wi-Fi, Ethernet or both connections?
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
Hi Reece,
Really appreciate the prompt response and your offer to look at /monitor this.
I made a change over the weekend (swapped out the router I was using connected to the Hub 5) and I’ve seen a significant improvement, so may have been a local issue after all. I will monitor over the next week and let you know if I see a repeat, otherwise hopefully confirm all stable again.
Thank you!
Andrew
Natalie_L
Thank you for getting back in touch and letting us know you have seen improvements with the service.
Please do reach out if anything changes and if we can assist in the future.
Nat
Hi Nat,
Thanks for checking in.
Since swapping out my router (got Hub in modem mode) the situation has definitely improved (in terms of packet loss), although yesterday just after 2pm GMT I lost complete connectivity (for 10/15mins), was in a video meeting at the time (mainly WFH).
Checking the Network log around that time see CRITICALs...
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
No Ranging Response received - T3 time-out
Also today started getting WARNINGS..
Dynamic Range Window violation
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Please let me know if you or the team are able help. Let me know if need me to take out of modem mode.
Thank you for your time and help
Andrew
Another brief outage…at the same time spotted in network log…
16 consecutive T3 timeouts while trying to range on upstream channel 8
It’s frustrating because seems very intermittent.
Thanks again for any advice.
Andrew
Hey andrewpieri, thank you for reaching out and I am sorry you are having some connection issues.
I have taken a look and I can see there was an SNR outage over the weekend however this has now been fixed.
Has your connection been fully restored? Thanks
Matt - Forum Team
New around here?
Hi Matt,
Thanks for the update, it’s good to hear that the weekend issue has been resolved.
The connection has been stable since, but will monitor over next few days and advise if hit any issues.
Really appreciate your help.
Andrew
Problem has returned out of the blue, still intermittent, similar pattern on BQM.
Tried different routers when in modem mode. I also tried to simplify the cabling in case was related (removed TV splitter), but still the same.
I have reverted the Hub 5 to regular router mode, in case helps with monitoring. I will monitor this over the next day or so.
Really appreciate any help/advice the VM team can offer.
Andrew
Following my last message and to add...as part of reverting the Hub 5 to router mode.
Initially struggled to publish SSIDs on 2.4 and 5GHz bands (stuck as disabled) regardless of what I selected (manual or auto).
I factory reset the Hub 5 and thought that it had resolved the issue, but can now see that only broadcasting on 2.4GHz band. When I try to enable the 5GHz band it says configuring wireless settings, but then returns the wireless status page and has 5GHz disabled.
Not sure if related to the broader problems I have been experiencing but thought would share in case.
Thanks again
Andrew
