on 30-09-2022 17:27
on 30-09-2022 17:33
Alas, no the passwords are (fairly) randomly setup when the hub is manufactured, nobody will know what the default password for your particular hub is. The only option is for you to call VM and try to get a technician visit to replace the entire hub with another one.
on 03-10-2022 09:46
Hey Raymath1, thank you for reaching out and I am sorry to hear you have forgot your password.
The Hub 3 will also come with a card with your WIFI SSID and password on, have you had a look for this? Have you got a PC or laptop connected as you should be able to check the WIFI password on those devices under your network settings.
Please do let me know and we can take it from there. Thanks
Matt - Forum Team
New around here?
on 03-10-2022 18:42
Open up computer on network settings but can't find password
on 05-10-2022 20:07
Thanks for the response,
Can I ask did you receive a card at all with the details on it? Or a sticker?
Let us know,
