on 18-05-2024 14:35
I've been experiencing intermittent loss of broadband signal for a few months now. I've put up with it for long enough. The following BQM graphs are from the last 5 days. But I have a couple of months of graphs showing exactly the same thing. My Network Log shows quite clearly that this is a SYNC Timing Synchronization failure - Loss of Sync
Rebooting the system doesn't make any difference. I've checked to make sure all my connections are tightened. I'd like an engineer visit to address the ongoing issues asap. Thanks.
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 387000000 | 1.2 | 35 | 256 qam | 32 |
2 | 139000000 | 2.7 | 35 | 256 qam | 1 |
3 | 147000000 | 2.9 | 35 | 256 qam | 2 |
4 | 155000000 | 2.9 | 35 | 256 qam | 3 |
5 | 163000000 | 2.7 | 35 | 256 qam | 4 |
6 | 171000000 | 2.7 | 35 | 256 qam | 5 |
7 | 179000000 | 2.4 | 35 | 256 qam | 6 |
8 | 187000000 | 2.2 | 35 | 256 qam | 7 |
9 | 195000000 | 2 | 35 | 256 qam | 8 |
10 | 203000000 | 1.7 | 35 | 256 qam | 9 |
11 | 211000000 | 1.5 | 35 | 256 qam | 10 |
12 | 219000000 | 1 | 35 | 256 qam | 11 |
13 | 227000000 | 1 | 35 | 256 qam | 12 |
14 | 235000000 | 1.2 | 35 | 256 qam | 13 |
15 | 299000000 | 2 | 35 | 256 qam | 21 |
16 | 307000000 | 2 | 35 | 256 qam | 22 |
17 | 315000000 | 2.2 | 35 | 256 qam | 23 |
18 | 323000000 | 2 | 35 | 256 qam | 24 |
19 | 339000000 | 1.9 | 35 | 256 qam | 26 |
20 | 347000000 | 1.5 | 35 | 256 qam | 27 |
21 | 355000000 | 1.5 | 35 | 256 qam | 28 |
22 | 363000000 | 2 | 35 | 256 qam | 29 |
23 | 371000000 | 1.7 | 35 | 256 qam | 30 |
24 | 379000000 | 1.4 | 35 | 256 qam | 31 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 35.7 | 160341 | 373423 |
2 | Locked | 35.5 | 155601 | 469198 |
3 | Locked | 35.5 | 175170 | 478554 |
4 | Locked | 35.7 | 154009 | 470716 |
5 | Locked | 35.5 | 160718 | 463135 |
6 | Locked | 35.5 | 170242 | 471938 |
7 | Locked | 35.7 | 152556 | 461006 |
8 | Locked | 35.5 | 170819 | 460889 |
9 | Locked | 35.5 | 164720 | 458720 |
10 | Locked | 35 | 177538 | 451623 |
11 | Locked | 35 | 205178 | 450675 |
12 | Locked | 35 | 201775 | 448642 |
13 | Locked | 35 | 210429 | 454224 |
14 | Locked | 35 | 219283 | 425077 |
15 | Locked | 35 | 215540 | 402858 |
16 | Locked | 35.7 | 159671 | 423299 |
17 | Locked | 35.5 | 161059 | 427630 |
18 | Locked | 35.5 | 160822 | 414453 |
19 | Locked | 35.7 | 162887 | 399939 |
20 | Locked | 35.7 | 167893 | 407648 |
21 | Locked | 35.7 | 157770 | 413033 |
22 | Locked | 35.5 | 174583 | 375605 |
23 | Locked | 35.7 | 170645 | 372924 |
24 | Locked | 35.5 | 173927 | 381164 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 43100000 | 47.5 | 5120 | 64 qam | 10 |
2 | 23600000 | 47 | 5120 | 64 qam | 13 |
3 | 30100000 | 47 | 5120 | 64 qam | 12 |
4 | 36600000 | 48 | 5120 | 64 qam | 11 |
5 | 49600000 | 49 | 5120 | 64 qam | 9 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 9 | 0 |
2 | ATDMA | 0 | 0 | 9 | 0 |
3 | ATDMA | 0 | 0 | 6 | 0 |
4 | ATDMA | 0 | 0 | 7 | 0 |
5 | ATDMA | 0 | 0 | 11 | 0 |
Time | Priority | Description |
18/05/2024 13:54:16 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:47:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:45:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:27:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:27:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:26:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:26:46 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:12:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 13:12:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:50:0 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:50:0 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:45:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:45:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:28:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 11:28:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 04:47:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 04:47:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 03:57:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 03:57:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/05/2024 03:08:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 19-05-2024 11:25
What they never volunteer is that you are entitled to claim for compensation of £30.49 if VM fails to attend at the appointed time https://www.virginmedia.com/help/billing-and-payments/automatic-compensation
on 19-05-2024 15:14
Good to know. Thanks for the heads up. 👍
on 19-05-2024 15:16
I've experienced issues trying to change the date/time of the appointment. Please respond to message sent.
on 23-05-2024 14:12
So the Engineer’s just been. He changed all the cabling indoors. He said that the readings outside at the main box were iffy so he’s referred this to a Network guy who will apparently check this out in the next couple of days. While the Engineer was still here, the wi-fi went down again.
He then suggested it could be one of my devices knocking out the signal at the hub.
Told me to switch off one of my devices at a time. Leave it off for a couple of hours and monitor for drop outs in that time.
I wondered how long it would take for Virgin to suggest the fault isn’t caused by their equipment.
I’ll do what he suggested.
If this issue isn’t resolved soon I’ll be cancelling the last few months of my contact and taking my business elsewhere. I’ve been with you 23 years.
on 28-05-2024 16:12
I'm still waiting to hear from you re a response from the Area Field Manager [Please see private messages] No change in the issues detailed previously. Here are today's readings from BQM and the hub.
1 | 331000000 | 5.9 | 35 | 256 qam | 25 |
2 | 139000000 | 6.5 | 35 | 256 qam | 1 |
3 | 147000000 | 6.5 | 35 | 256 qam | 2 |
4 | 155000000 | 6.5 | 35 | 256 qam | 3 |
5 | 163000000 | 6.3 | 35 | 256 qam | 4 |
6 | 171000000 | 6.1 | 35 | 256 qam | 5 |
7 | 179000000 | 6 | 35 | 256 qam | 6 |
8 | 187000000 | 5.9 | 35 | 256 qam | 7 |
9 | 195000000 | 5.6 | 35 | 256 qam | 8 |
10 | 203000000 | 5.4 | 35 | 256 qam | 9 |
11 | 211000000 | 5 | 34 | 256 qam | 10 |
12 | 219000000 | 4.8 | 35 | 256 qam | 11 |
13 | 227000000 | 4.6 | 34 | 256 qam | 12 |
14 | 235000000 | 4.5 | 35 | 256 qam | 13 |
15 | 299000000 | 6 | 35 | 256 qam | 21 |
16 | 307000000 | 5.6 | 35 | 256 qam | 22 |
17 | 315000000 | 5.5 | 35 | 256 qam | 23 |
18 | 323000000 | 5.8 | 35 | 256 qam | 24 |
19 | 339000000 | 5.8 | 35 | 256 qam | 26 |
20 | 355000000 | 5.5 | 35 | 256 qam | 28 |
21 | 363000000 | 5.9 | 35 | 256 qam | 29 |
22 | 371000000 | 5.5 | 35 | 256 qam | 30 |
23 | 379000000 | 5.3 | 35 | 256 qam | 31 |
24 | 387000000 | 5.4 | 35 | 256 qam | 32 |
1 | Locked | 35.7 | 7128 | 46349 |
2 | Locked | 35 | 18341 | 43043 |
3 | Locked | 35 | 16698 | 45851 |
4 | Locked | 35.5 | 14051 | 43537 |
5 | Locked | 35.5 | 14118 | 45258 |
6 | Locked | 35 | 16669 | 45979 |
7 | Locked | 35.5 | 14203 | 45925 |
8 | Locked | 35 | 22650 | 44636 |
9 | Locked | 35.5 | 15795 | 45093 |
10 | Locked | 35 | 17497 | 44740 |
11 | Locked | 34.9 | 24817 | 44386 |
12 | Locked | 35 | 18265 | 45477 |
13 | Locked | 34.9 | 26228 | 45996 |
14 | Locked | 35 | 31744 | 46230 |
15 | Locked | 35.7 | 12146 | 48258 |
16 | Locked | 35.7 | 7643 | 45787 |
17 | Locked | 35.7 | 8130 | 48285 |
18 | Locked | 35.5 | 8006 | 47891 |
19 | Locked | 35.7 | 6533 | 48933 |
20 | Locked | 35.7 | 6389 | 47856 |
21 | Locked | 35.5 | 6669 | 46551 |
22 | Locked | 35.7 | 6236 | 46395 |
23 | Locked | 35.5 | 6792 | 47579 |
24 | Locked | 35.7 | 5890 | 46759 |
1 | 43100000 | 39 | 5120 | 64 qam | 10 |
2 | 23600000 | 37.5 | 5120 | 64 qam | 13 |
3 | 30100000 | 37.5 | 5120 | 64 qam | 12 |
4 | 36600000 | 39 | 5120 | 64 qam | 11 |
5 | 49600000 | 39 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 1 | 0 |
28/05/2024 16:03:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 15:41:58 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 15:23:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 15:09:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 15:09:10 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 13:42:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 13:42:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 13:02:21 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 09:54:19 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 07:46:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 07:46:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 07:29:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 07:27:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 05:43:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 05:43:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 05:11:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 05:11:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 04:15:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 04:15:17 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/05/2024 03:11:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
