Need Help ASAP With Sync Timing Issue ...
c0balt
I've been experiencing intermittent loss of broadband signal for a few months now. I've put up with it for long enough. The following BQM graphs are from the last 5 days. But I have a couple of months of graphs showing exactly the same thing. My Network Log shows quite clearly that this is a SYNC Timing Synchronization failure - Loss of Sync
Rebooting the system doesn't make any difference. I've checked to make sure all my connections are tightened. I'd like an engineer visit to address the ongoing issues asap. Thanks.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
387000000
1.2
35
256 qam
32
2
139000000
2.7
35
256 qam
1
3
147000000
2.9
35
256 qam
2
4
155000000
2.9
35
256 qam
3
5
163000000
2.7
35
256 qam
4
6
171000000
2.7
35
256 qam
5
7
179000000
2.4
35
256 qam
6
8
187000000
2.2
35
256 qam
7
9
195000000
2
35
256 qam
8
10
203000000
1.7
35
256 qam
9
11
211000000
1.5
35
256 qam
10
12
219000000
1
35
256 qam
11
13
227000000
1
35
256 qam
12
14
235000000
1.2
35
256 qam
13
15
299000000
2
35
256 qam
21
16
307000000
2
35
256 qam
22
17
315000000
2.2
35
256 qam
23
18
323000000
2
35
256 qam
24
19
339000000
1.9
35
256 qam
26
20
347000000
1.5
35
256 qam
27
21
355000000
1.5
35
256 qam
28
22
363000000
2
35
256 qam
29
23
371000000
1.7
35
256 qam
30
24
379000000
1.4
35
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35.7
160341
373423
2
Locked
35.5
155601
469198
3
Locked
35.5
175170
478554
4
Locked
35.7
154009
470716
5
Locked
35.5
160718
463135
6
Locked
35.5
170242
471938
7
Locked
35.7
152556
461006
8
Locked
35.5
170819
460889
9
Locked
35.5
164720
458720
10
Locked
35
177538
451623
11
Locked
35
205178
450675
12
Locked
35
201775
448642
13
Locked
35
210429
454224
14
Locked
35
219283
425077
15
Locked
35
215540
402858
16
Locked
35.7
159671
423299
17
Locked
35.5
161059
427630
18
Locked
35.5
160822
414453
19
Locked
35.7
162887
399939
20
Locked
35.7
167893
407648
21
Locked
35.7
157770
413033
22
Locked
35.5
174583
375605
23
Locked
35.7
170645
372924
24
Locked
35.5
173927
381164
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
43100000
47.5
5120
64 qam
10
2
23600000
47
5120
64 qam
13
3
30100000
47
5120
64 qam
12
4
36600000
48
5120
64 qam
11
5
49600000
49
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
9
0
2
ATDMA
0
0
9
0
3
ATDMA
0
0
6
0
4
ATDMA
0
0
7
0
5
ATDMA
0
0
11
0
Time
Priority
Description
18/05/2024 13:54:16
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2024 13:47:18
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2024 13:45:47
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2024 13:27:37
Warning!
18/05/2024 13:27:37
critical
18/05/2024 13:26:46
Warning!
18/05/2024 13:26:46
critical
18/05/2024 13:12:47
Warning!
18/05/2024 13:12:47
critical
18/05/2024 11:50:0
Warning!
18/05/2024 11:50:0
critical
18/05/2024 11:45:11
Warning!
18/05/2024 11:45:11
critical
18/05/2024 11:28:55
Warning!
18/05/2024 11:28:32
critical
18/05/2024 04:47:37
Warning!
18/05/2024 04:47:37
critical
18/05/2024 03:57:49
Warning!
18/05/2024 03:57:49
critical
18/05/2024 03:08:14
Warning!
14 REPLIES 14
Not great - but can you start from a clean sheet and do this..
___________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Also check the Upstream QAM’s are all at 64
The only thing I wasn't able to do was check outside. As I'm housebound.
These were taken 5 mins after hub reset ...
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
387000000
1.7
35
256 qam
32
2
139000000
3
35
256 qam
1
3
203000000
2
34
256 qam
9
4
211000000
1.7
35
256 qam
10
5
219000000
1.2
35
256 qam
11
6
227000000
1.2
34
256 qam
12
7
235000000
1.4
35
256 qam
13
8
243000000
1.2
35
256 qam
14
9
251000000
1
35
256 qam
15
10
259000000
1.2
35
256 qam
16
11
267000000
1.7
35
256 qam
17
12
275000000
2.2
35
256 qam
18
13
283000000
2
35
256 qam
19
14
291000000
1.7
35
256 qam
20
15
299000000
2.2
35
256 qam
21
16
307000000
2.2
35
256 qam
22
17
315000000
2.5
35
256 qam
23
18
323000000
2.5
35
256 qam
24
19
339000000
2.2
35
256 qam
26
20
347000000
1.9
35
256 qam
27
21
355000000
2
35
256 qam
28
22
363000000
2.2
35
256 qam
29
23
371000000
2
35
256 qam
30
24
379000000
1.7
35
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35.5
21
263
2
Locked
35.5
27
168
3
Locked
34.9
29
248
4
Locked
35
19
250
5
Locked
35
22
201
6
Locked
34.9
30
208
7
Locked
35
33
189
8
Locked
35
18
276
9
Locked
35
22
280
10
Locked
35.5
21
318
11
Locked
35.5
27
160
12
Locked
35.7
26
256
13
Locked
35.5
30
203
14
Locked
35.5
20
243
15
Locked
35.5
30
181
16
Locked
35.5
21
216
17
Locked
35.5
37
172
18
Locked
35.7
30
262
19
Locked
35.7
18
304
20
Locked
35.5
16
164
21
Locked
35.7
17
167
22
Locked
35.7
15
251
23
Locked
35.7
21
298
24
Locked
35.7
25
188
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
43099998
46.5
5120
64 qam
10
2
23600017
45
5120
64 qam
13
3
30100019
46.5
5120
64 qam
12
4
36600004
46.5
5120
64 qam
11
5
49600019
48.5
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
0
0
Time
Priority
Description
18/05/2024 16:46:54
notice
18/05/2024 16:46:41
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2024 16:31:6
Warning!
18/05/2024 16:31:6
critical
18/05/2024 16:30:54
Warning!
18/05/2024 16:30:54
critical
18/05/2024 16:30:50
Warning!
18/05/2024 16:30:50
critical
18/05/2024 16:26:58
Warning!
18/05/2024 16:25:33
critical
18/05/2024 14:34:43
Warning!
18/05/2024 14:26:24
critical
18/05/2024 13:55:46
Warning!
18/05/2024 13:55:46
critical
18/05/2024 13:54:16
notice
18/05/2024 13:47:18
Warning!
18/05/2024 13:45:47
critical
18/05/2024 13:27:37
Warning!
18/05/2024 13:27:37
critical
18/05/2024 13:26:46
Warning!
OK - thats not good - too many PostRS Errors, SNR's are all low and the BQM looks awful.
What devices do you have connected to the Hub on ethernet cables ?
A VM Person will be along here soon and take a look for you
Thanks for reaching out to us @c0balt, and I'm sorry to hear of the issues you've been experiencing with the services.
Check out the envelope in the top right hand corner for a private message from me, and I'll be able to take some details from you and take a closer look into this for you.
David_Bn
Okay so I've just checked the Downstream and Upstream and Network log again. An hour since the last readings as you advised. Do things look any better to you??? 🤞
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
387000000
1.9
35
256 qam
32
2
139000000
3.2
35
256 qam
1
3
203000000
2.2
35
256 qam
9
4
211000000
1.9
35
256 qam
10
5
219000000
1.5
34
256 qam
11
6
227000000
1.4
34
256 qam
12
7
235000000
1.5
34
256 qam
13
8
243000000
1.2
35
256 qam
14
9
251000000
1.2
35
256 qam
15
10
259000000
1.4
35
256 qam
16
11
267000000
2
35
256 qam
17
12
275000000
2.4
35
256 qam
18
13
283000000
2.2
35
256 qam
19
14
291000000
2
35
256 qam
20
15
299000000
2.5
35
256 qam
21
16
307000000
2.5
35
256 qam
22
17
315000000
2.7
35
256 qam
23
18
323000000
2.5
35
256 qam
24
19
339000000
2.2
35
256 qam
26
20
347000000
2
35
256 qam
27
21
355000000
2
35
256 qam
28
22
363000000
2.5
35
256 qam
29
23
371000000
2.2
35
256 qam
30
24
379000000
2
35
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35.7
92
299
2
Locked
35
142
168
3
Locked
35
170
292
4
Locked
35
173
271
5
Locked
34.9
207
201
6
Locked
34.9
201
253
7
Locked
34.9
189
269
8
Locked
35
155
350
9
Locked
35
177
316
10
Locked
35
140
347
11
Locked
35
166
216
12
Locked
35.5
115
423
13
Locked
35
155
293
14
Locked
35.5
121
301
15
Locked
35
151
288
16
Locked
35.5
97
239
17
Locked
35.5
105
230
18
Locked
35.5
90
356
19
Locked
35.7
81
333
20
Locked
35.7
88
188
21
Locked
35.5
73
207
22
Locked
35.5
86
317
23
Locked
35.5
74
325
24
Locked
35.7
77
234
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
43099998
46.5
5120
64 qam
10
2
23600017
45
5120
64 qam
13
3
30100019
45
5120
64 qam
12
4
36600004
46.5
5120
64 qam
11
5
49600019
48.5
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
0
0
Time
Priority
Description
18/05/2024 16:46:54
notice
18/05/2024 16:46:41
Warning!
18/05/2024 16:31:6
Warning!
18/05/2024 16:31:6
critical
18/05/2024 16:30:54
Warning!
18/05/2024 16:30:54
critical
18/05/2024 16:30:50
Warning!
18/05/2024 16:30:50
critical
18/05/2024 16:26:58
Warning!
18/05/2024 16:25:33
critical
18/05/2024 14:34:43
Warning!
18/05/2024 14:26:24
critical
18/05/2024 13:55:46
Warning!
18/05/2024 13:55:46
critical
18/05/2024 13:54:16
notice
18/05/2024 13:47:18
Warning!
18/05/2024 13:45:47
critical
18/05/2024 13:27:37
Warning!
18/05/2024 13:27:37
critical
18/05/2024 13:26:46
Warning!
Nope 😨
Reply to David's PM as per above - he will sort it out for you
Will do. Thanks for your help.
Responded as requested.
Thanks for coming back to me over private message @c0balt, I've been able to book in an engineer appointment for you.
For details of the time and date of the appointment, and if you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
Furthermore, I'd need to advise that;
There will be no charge for this visit unless:
  • The technician diagnoses the faults as not being caused by our network/equipment
  • The technician discovers that the fault or problem relates to your equipment
  • The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Please ensure there is someone over the age of 18 present at the time of the visit.
We will continue to monitor your services and if we can see that the fault has cleared and the visit is no longer required we will cancel the appointment and let you know by text and email.
David_Bn
