on 05-08-2023 20:47
Hi All. Our Hub3 seemed to kick the bucket this week. Decided to reboot our ASUS router due to some issues, post reboot it wouldn’t sync and was red lighting on the connection led.
Called tech support and got a hub 5 sent out. Same issue, regardless of which sequence I boot, leave with the power off, cables used. Replaced the ASUS router in case it had actually died, and a tp link also won’t sync to the modem.
last call to TS had them rebooting to router mode trying to split the wifi????
Is there something glaring lot obvious in missing ?
on 07-08-2023 11:45
Hi there @RougePenguin
Thank you so much for your post and welcome to the community forums, it's great to have you back.
I am so sorry that you have faced this issue with your service and thank you again for posting. Can I just confirm did you split your WiFi 2.4 and 5 frequencies?
on 07-08-2023 20:13
Hi Ashleigh,
I'm it sure why they tried to split the wifi. I want to use the hub 5 in modem mode, with my ASUS router. Also tried another router to make sure it want that router that had died, but that got no signal either.
Could it be an incoming level issue?
07-08-2023 20:40 - edited 07-08-2023 20:40
Probably first thing to check is your setup.
Is there only one Ethernet cable connected to the HUB 5, and it's between it and the Asus router?
Is the LED on the HUB 5 green?
on 08-08-2023 09:26
If you are using 3rd party contract we can't guarantee our equipment won't work with it and when it does it won't work. 100%.
I have taken a look at our side and everything is look great connection wise. Cheers
Matt - Forum Team
New around here?
on 08-08-2023 12:38
Yup. It’s been running fine for 3 years.
all cables replaced, second router tried, just not getting a connection to another router.
on 08-08-2023 12:41
Thanks Matt, as I just mentioned, the Hub3 was working find on modem mode for 3 years. Replaced Ethernet cables to make sure nothings wrong there.
thanks for checking the set up, must just be bad luck that both routers are faulty (admittedly, the second test one is a lot older)
on 08-08-2023 12:44
No problem at all, it could also be the wires have you replaces them with a CAT6 for example?
If so if you have an old router it may not work as well with CAT6 wires as the router may not fully support them. Cheers
Matt - Forum Team
New around here?
on 08-08-2023 13:42
You can test the VM hubs ports by plugging both ends of an Ethernet cable into two ports in the hub. The LEDs should show green if the ports are ok.
