on 01-02-2022 23:58
Evening,
This has happened a few times lately, I'll notice my phone isn't on WiFi, my home network won't be there, wait a little bit and it'll appear my phone will connect and it'll disappear again until eventually it stays on.
Also, the WiFi signal is and always has been terrible.. I've tried to get help on this before but just got fobbed off saying it must be where it's placed, it's in the same place previous routers were placed and they had no issues at all. I've lived with it until now but a few things have changed meaning I rely on the WiFi signal more.
I'm not paying for boosters when the hub should be capable of giving a WiFi signal more than 10ft away from Itself, just checking if anything can be done before I cancel.
Thanks Alex
Answered! Go to Answer
02-02-2022 15:05 - edited 02-02-2022 15:07
It's not logical to say every other router I've had worked flawlessly in the same location where the hub barely works because internally they're different?
According to the terms the hub I have is the property of virgin media and the use/rental of it is factored into what I pay each month. And according to ofcom virgin media are indeed liable for the WiFi speeds as long as it's within a reasonable distance etc. I'd say expecting Alexa to be able to stream music 10ft away was reasonable.
on 02-02-2022 01:15
on 02-02-2022 10:35
Apologies, should have added more info. It's the hub 3. I've had them separated and I've had it set manually on different WiFi channels and it's the same just painfully slow unless the device is right next to the hub.
Seems to be a well documented issue online with the hubs, or the hub 3 at least.
on 02-02-2022 10:37
That's what I want mine for mainly gaming and it's just not up too it, can't run a cable anymore and it's unusuable upstairs even though it's directly above the hub
on 02-02-2022 11:05
on 02-02-2022 11:09
Lol I'm not a competitive gamer, it should be playable over WiFi when it's about 3m from the hub I pay for 100Mb and get about 1Mb with a huge ping.
Its my only option at the minute, there's no way it should drop that much, same for other devices
on 02-02-2022 11:10
on 02-02-2022 11:13
Yes I know.
Wired varies, sometimes it's full speed others it's half.
If I test my speed wired and it's at full speed I can into the next room with the laptop on 5ghz and it'll barely be 1Mb, same for upstairs. Obviously it's going to drop on WiFi but drop that much? I don't think so.
on 02-02-2022 11:14
on 02-02-2022 11:21
Yes, all of that. They blamed congestion at first until I told them there's no other WiFi within range of me. Seems well documented online about the hub 3
