on 09-12-2021 17:38
Hello,
On previous Virgin Media Hubs, you had the option to dim the lights on the hub itself. Hub 5 does not appear to have said option.
Does anyone know if this feature/function is hidden somewhere in the menu?
Or someone form Virgin Media, will this option be brought back?
on 09-12-2021 17:55
On the Hub 3 this feature was only found under the menu item "Purchase black electrical tape, cut to size and fit neatly for a smart finish".
on 09-12-2021 18:48
It certainly seems the Hub3’s firmware has been carried over to the Hub5!
