on 17-08-2021 12:07
Hi and sorry if this has been answered a thousand times.
running a superhub 3 and it currently has around 35 to 40 wired and wireless connections at any one time. The hub constantly drops the internet or the delay increases and you have to reboot it several times a day just to keep everything running smooth-ish.
since the pandemic our problems and speeds have been rubbish. We have gone from around an average of 220mbps to around 40mbps recently.
i hear many times its better to have the superhub in modem mode and use a third party wireless router is this the best way? If so which one that can handle all todays modern wireless everything?
any help or suggestions greatly appreciated.
on 17-08-2021 12:18
on 17-08-2021 12:22
You're possibly pushing your luck with that many devices, and in my experience a modern mesh wifi setup is vastly better adapted to current needs than the ageing Hub 3, or indeed the newer Hub 4. As a personal view just about any competent mesh wifi system that has gigabit ethernet ports would work fine - I use a near entry level TP-Link Deco M4, the newer S4 would be virtually identical, but you can spend a lot more if you want, and there's plenty of different makes on the market.
But before you start salivating over the idea of splashing out on new technology in the hope of a quick fix, the slow speeds suggest to me a broadband problem is possible. Connect to the hub by clicking on this link http://192.168.0.1/ That should pull up the log in page for the hub. But don't log in, just click on the link "Check router status" That'll bring up a window with five tabs. Open the Downstream tab. Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots. Post that, do the same for the Upstream and Network log. You'll get an error message when you post the Network log, just click on "post" a second time. Then we can check for any obvious problems with power, noise or error counts.
on 17-08-2021 15:22
TimePriorityDescription17/08/2021 08:04:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:04:28criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:01:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:01:19criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:59criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:39criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2021 08:00:19criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;16/08/2021 18:34:7noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:54criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:54Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:30Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:15Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;16/08/2021 18:32:44Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 17-08-2021 15:27
on 17-08-2021 15:59
Sorry thought i had will try again
on 17-08-2021 16:02
Downstream
1 | 298750000 | 2 | 40 | 256 qam | 21 |
2 | 138750000 | 4 | 40 | 256 qam | 1 |
3 | 146750000 | 4 | 40 | 256 qam | 2 |
4 | 154750000 | 3.9 | 40 | 256 qam | 3 |
5 | 162750000 | 3.7 | 40 | 256 qam | 4 |
6 | 170750000 | 3.5 | 40 | 256 qam | 5 |
7 | 178750000 | 3.2 | 40 | 256 qam | 6 |
8 | 186750000 | 3 | 40 | 256 qam | 7 |
9 | 194750000 | 2.9 | 40 | 256 qam | 8 |
10 | 202750000 | 2.5 | 40 | 256 qam | 9 |
11 | 210750000 | 2.5 | 40 | 256 qam | 10 |
12 | 218750000 | 2.4 | 40 | 256 qam | 11 |
13 | 226750000 | 2.4 | 40 | 256 qam | 12 |
14 | 234750000 | 2.4 | 40 | 256 qam | 13 |
15 | 242750000 | 2.2 | 40 | 256 qam | 14 |
16 | 250750000 | 2.2 | 40 | 256 qam | 15 |
17 | 258750000 | 2 | 40 | 256 qam | 16 |
18 | 266750000 | 2 | 40 | 256 qam | 17 |
19 | 274750000 | 1.9 | 40 | 256 qam | 18 |
20 | 282750000 | 1.9 | 40 | 256 qam | 19 |
21 | 290750000 | 2 | 40 | 256 qam | 20 |
22 | 306750000 | 1.9 | 40 | 256 qam | 22 |
23 | 314750000 | 1.5 | 40 | 256 qam | 23 |
24 | 322750000 | 1.5 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 15 | 0 |
2 | Locked | 40.9 | 2 | 22 |
3 | Locked | 40.3 | 17 | 0 |
4 | Locked | 40.9 | 18 | 0 |
5 | Locked | 40.3 | 15 | 0 |
6 | Locked | 40.9 | 21 | 0 |
7 | Locked | 40.3 | 19 | 0 |
8 | Locked | 40.9 | 19 | 0 |
9 | Locked | 40.3 | 5 | 0 |
10 | Locked | 40.3 | 5 | 0 |
11 | Locked | 40.3 | 4 | 0 |
12 | Locked | 40.9 | 5 | 0 |
13 | Locked | 40.9 | 6 | 0 |
14 | Locked | 40.9 | 5 | 0 |
15 | Locked | 40.3 | 5 | 0 |
16 | Locked | 40.9 | 5 | 0 |
17 | Locked | 40.9 | 4 | 0 |
18 | Locked | 40.3 | 10 | 0 |
19 | Locked | 40.9 | 5 | 0 |
20 | Locked | 40.3 | 5 | 0 |
21 | Locked | 40.3 | 4 | 0 |
22 | Locked | 40.3 | 21 | 0 |
23 | Locked | 40.9 | 19 | 0 |
24 | Locked | 40.3 | 19 | 0 |
on 17-08-2021 16:30
1 | 53700000 | 51 | 5120 | 64 qam | 10 |
2 | 39400000 | 51 | 5120 | 64 qam | 12 |
3 | 46200000 | 51 | 5120 | 64 qam | 11 |
4 | 60300000 | 52.5 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 17-08-2021 16:41
All upstream channels are too high.
First check to see if there are any area problems and if not call customer services, numbers below. If there are any area problems, check again when it says they are fixed and if you still have problems then call customer services. VM will not send out any technicians until any area fault is fixed.
Call Customer Services on 0345 454 1111 or if you have a VM landline 150
Check with Area faults on 150 or 0800 561 0061
on 18-08-2021 11:20
Thanks for that they are showing no area problems so i will log a fault with them.
i take it the upstream being too high is not also related to the tv box? Just i remember them saying a few yrs back they had left them a little bit high to keep the signal up as the last tivo box was quite a distance away 🤷🏼♂️
on another note if i have pushing 40 items on wireless is too much for any hub and if so can modems easily carry this much?
any other recommendations apart from already suggested? Im using 2 tp link boosters in the house but not sure the VM hub likes them or is it just the fault?
appreciate all the help 👍🏼
