12-06-2021 09:23 - edited 12-06-2021 09:25
HI
Thought I'd give this a go... cant seem to get it resolved?
The connection is stable then just randomly starts to drop and the hub starts doing its reboot cycle
We have had engineers out twice 1 replaced the standard cables , connection and wall box bit and pieces next replaced the router
All ok for about 5 days then it started again I switched plugs thinking it may be with the plug
details added below from reading the forum... if theres anything else let m know any help will be greatly appreciated... thanks in advance.
12/06
11/06
10/06
09/06 -- 6pm was a reboot/unplug
08/06
exceeded 200000 characters??? removed some tables - let me know if required I will try add
Time | Priority | Description |
11/06/2021 22:31:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
11/06/2021 19:56:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
11/06/2021 16:45:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 20:13:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 17:03:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 17:02:44 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
10/06/2021 03:50:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
09/06/2021 13:27:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
09/06/2021 01:58:22 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
08/06/2021 16:51:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
08/06/2021 16:22:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
07/06/2021 11:35:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
06/06/2021 08:42:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
05/06/2021 04:28:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
05/06/2021 00:34:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 15:32:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 13:10:27 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 11:55:42 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 11:55:42 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
04/06/2021 10:57:55 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
on 22-06-2021 11:48
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | A,.iyewrkldJKDHSUBsgvca69834n |
SFID | 15462 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 14454 |
Max Traffic Rate | 22000047 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 22-06-2021 11:52
21/06/2021 16:34:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
21/06/2021 10:17:18 | notice | LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
19/06/2021 16:01:8 | critical | No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 21:02:51 | notice | LAN login Success;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 13:48:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
18/06/2021 13:15:17 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:29:47 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:29:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:29:45 | Warning! | Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:29:40 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:29:40 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:49 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:46 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:38 | Warning! | Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:34 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:34 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
17/06/2021 10:28:33 | Warning! | RCS Partial Service;CM-MAC=xx:xx:xx:xx:xx:xxCMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0; |
on 22-06-2021 13:04
Hello @0110jeff.
Thank you for posing on the community page 🙂 Hope you are well.
I am sorry for the recent internet issues, I have tried to locate your account using your forums details but unable to find an active media account? Have you recently left us?
Look forward to your response.
on 22-06-2021 13:47
Hi Hayley
Its in my wife's name
on 22-06-2021 14:06
Okay no problem @0110jeff.
I will send you a private message so we can locate the account.
Look forward to speaking with you.
on 22-06-2021 15:14
no better
on 22-06-2021 15:23
Thank you for talking to me in private @0110jeff.
As you are not the account holder I am unable to share the appointment date with you, please check with the account holder for the appointment date and time.
Let me know if this is okay for you both.
Many thanks.
on 22-06-2021 17:47
we got it thank you
on 22-06-2021 17:53
Thank you for sharing this with me @0110jeff.
I am glad that this is okay for you 🙂
Please let me know how it goes.
on 23-06-2021 14:07
