on 17-04-2023 07:05
My hub 3 has a solid red light, I have restarted and factory reset but this still persists. I have done this a few times in the last few weeks but it has continued to be red rather than the original white. It still gets the Internet. The unit is in an open space and is warm at the top. I called support and they said this isn’t right but would not arrange a replacement ‘until it breaks’. Having read the forum this seems a potential problem with over heating and definitely needs replacing?
on 17-04-2023 07:21
on 17-04-2023 07:46
Thanks @lotharmat I’ll give them another call
on 19-04-2023 09:32
Hi Jhrnr,
Thanks for using the Community Forums to get this issue with your Hub looked into, I can see you've already been given some help by @lotharmat 😁
Were you able to get through to the faults team about this?
If not, we can still help on here. A red light on a Hub 3 - As long as it's not in Modem mode - Would be an overheating or faulty sensor issue which definitely needs looking at by an engineer. They will most likely replace the Hub after inspecting it 👨🔧
Please let us know!
Megan_L
on 19-04-2023 17:31
Thanks Megan - I’ve got a technician coming on Friday so hopefully they’ll be able to inspect and replace then. Thanks for following up.
James
on 21-04-2023 19:02
Thanks for letting us know James 🙂
Take care,
Alex_Rm
on 21-04-2023 19:04
Technician replaced the hub so hopefully problem solved - thanks everyone!
