on 08-03-2023 19:45
Hi there, less than a month ago I upgraded to a Hub 5 with 1Gbps connection. All has been working well, however over the course of the past week we've suddenly been having connection drop-outs. It appears to be happening more frequently as time goes on. I'm using the Hub 5 in Modem mode. I've tried resetting/restarting the Hub and Router with no success.
When the drop-outs occur, all devices stay connected to our router (wired and wifi) and the router/LAN functions as normal, however all devices lose connection to the internet at the same time. This issue appears to be isolated to the Hub 5 and possibly the connection outwith the house. A 6dB attenuator is in use.
The latest log is as below...
Quite a few instances of MDD message timeouts, all which seem to coincide with the loss of connection.
Any help is appreciated! I'll provide additional logs in following posts.
08-03-2023 19:12:09 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 19:10:20 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 19:09:58 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 17:53:36 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 17:52:26 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 17:51:58 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 16:14:26 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 16:12:50 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 16:12:40 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 10:50:59 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 10:49:31 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 10:49:06 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 10:34:43 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 08:40:11 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 08:40:08 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
08-03-2023 01:38:40 | notice | CM-STATUS message sent. Event Type Code: 4; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:51:29 | notice | CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:51:19 | warning | MDD message timeout;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:03:06 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:03:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:58 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
07-03-2023 20:02:52 | warning | Dynamic Range Window violation |
07-03-2023 20:02:52 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:52 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:46 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:43 | notice | TLV-11 - unrecognized OID;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:41 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:39 | notice | Honoring MDD; IP provisioning mode = IPv4 |
07-03-2023 20:02:30 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=*****;CMTS-MAC=*****;CM-QOS=1.1;CM-VER=3.1; |
07-03-2023 20:02:13 | critical | Cable Modem Reboot due to power button reset |
on 15-03-2023 17:32
Hi again Steven, apologies but please disregard the previous message. I had to give the team a call as the issue seems to be getting a lot worse. Multiple drops over the past hour. They think it may be an issue somewhere along the infrastructure and the engineers are actively going to monitor the connection over the coming days, so no engineer visit is needed at present. I'll provide an update on this thread once more information is available.
Thanks again for your help, much appreciated!
on 17-03-2023 17:51
Thanks for your response
Please do provide us with an update when you can and we'll be more than happy to investigate further. Have a great day
20-03-2023 19:43 - edited 20-03-2023 19:45
Problem sorted! It turns out it was the HUB 5 at fault.
It was swapped out by the engineer on Friday (it's now Monday) for a HUB 4. We've had 0 dropouts since and have a fast, stable connection once again.
Thanks everyone for the help!
