on 02-10-2021 21:02
I have just reconnected my 360 box after work done to the floor.
All OK apart from Internet connection. I have connected box to ethernet as it was before but no connection.
Any ideas anyone?
on 02-10-2021 21:13
Which cables were affected by the work to the floor?
Have you tried removing the Ethernet cable and making the connection by WiFi?
on 02-10-2021 21:20
Thanks for the reply.
I just had to unplug everything and move out of the room. I put it all back today all fine but ethernet connection is playing up.
Would rather sort this than do WIFI since I find it much better.
on 02-10-2021 22:23
Remove the Ethernet cable from both ends and replug, ensuring tight connections.
Reboot the internet Hub. Reboot the TV box.
