on 09-08-2022 21:51
Had hub 4 for several months. Everything worked fine up until 3wks ago. There was a drop out, the hub had solid white light but no devices would connect to WiFi and the v6 boxes had white arrow lights flashing. After rebooting sometimes taking couple reboots, it would resolve itself. Unfortunately this started happening mir often, going from once or twice a week to once or twice a day. The hub was changed, still had same issue. Next was the connection inside the white box, that was changed. Still same issue. Virgin say its a short term connectivity issue. What is happening here? The drops outs get extremely frustrating and two technicians haven't solved the issue. Doesn't help that neither technician actually checked the connections with their equipment to check signal or anything. Need help virgin because this issue is getting slowly worse
Answered! Go to Answer
on 10-08-2022 17:06
Wondering if there anyway I can show the drop outs? Seeing other threads noticed people show some numbers and errors. How can I access this in order to show you?
on 10-08-2022 18:17
on 10-08-2022 20:11
Okg. Signed up to that website earlier. Hwo do I go about showing you the graph?
on 11-08-2022 10:18
on 11-08-2022 10:32
Okay. Will do soon. Just to make you aware there is huge red part this due to turning hub off. We leave it off overnight. So far there's only been one dropped packet, but I suspect this happened because technician who I know checked the green box to check signals and we lost signal everywhere for about 2mins and then it came back
on 11-08-2022 15:11
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d59b041683a2a79368e4c93309518ae981d9704b
on 11-08-2022 15:21
11-08-2022 15:35 - edited 11-08-2022 15:38
That huge red block was because hub was off. That strange pattern around 6.30-7pm.... I'm almost certain it was the technician. I know a VM technician who lives nearby and he checked the green box across the road for the signal to make sure all is good. He was there for about 5mins and at that exact time I noticed were lost signal on the boxes and the Internet went weird, I think those spikes are cause of that cause it happened exactly at the time he was at the green box. WiFi has been absolutely fine since those times you can see, ethernet as said haven't got cable so can't check that. That same tech guy said our upstreams were out, but that was checked yesterday before the graph.
on 15-08-2022 08:48
HI MariaV,
Thank your for posting and for your updates with the information.
I am sorry to hear you are experiencing drop outs with the Hub 4.
Unfortunately, I am having issues viewing the graph via the link on the thread. If you have a new link please do share 🙂
Also, how have things been since your last post to the thread? Have you seen any improvements?
17-08-2022 11:55 - edited 17-08-2022 11:55
Hey
Unfortunately can't share the graph again as I've deleted the info from the site. Huh working fine and Internet now good. Tech came and replaced all the connections everywhere from the green box, so box outside the house to the white box inside our house and haven't had a single issues since. Seems fixed now. I understand we will be given £30 credit due to the issue and fact it taken 3 technicians to solve. But we can't see the credit on the account?
