on 28-10-2021 21:08
I'm on the M350 and it appears that I only get those kind of speeds in the AM when I first wake up. In the evenings, I'm getting around 60-100mb with constant drop outs. This has been going on for nearly a month now.
Tried calling Virgin a few times already and gone through the usual troubleshooting of reboots and resets but still the same performance. There were planned maintenance works carried out around a month ago as well so could be related. The last time I called the support agent claimed there was a flag on his end that there are issues around the area as I was on the call with him but I told him it had been happening for weeks but was told he can't escalate any further until they fix the 'issues' first.
I have the hub configured in modem mode and it goes into a TP-Link Archer C6 which then connects to a switch. Wifi access points are in nearly every room (wired) so I get full signal everywhere. Speeds tests are always carried out on a wired connection.
I've checked the logs on the hub (attached below). I suspect that it is an issue with the connection to the cabinet rather than a hardware issue but has anybody experienced anything similar and can tell me how I can get Virgin to actually do something rather than palming me off with excuses.
28/10/2021 19:52:9 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:45:46 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:40:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:40:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:35:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:35:50 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:35:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:35:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:35:21 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:28:14 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:15:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:15:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:13:43 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:13:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:12:58 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:12:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:11:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:11:45 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 19:08:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 01-11-2021 17:15
Hi meekowave,
Thank you for reaching out to us in our community and welcome, sorry to hear you are facing disconnections and slower than expected speeds, I have been able to locate you account with the details we have for you, as I can see you are using a 3rd party Router please put ours back in Router mode and carry out a Speed Test using speedtest.net.
What sped do you get when checking?
Paul.
on 04-11-2021 15:23
I have done this already and the speeds remain the same.
I just had another drop out and the logs on the hub shows the following:
04/11/2021 15:12:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2021 15:12:21 | critical | DCC aborted no UCD for new upstream channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 06-11-2021 17:35
Thanks for coming back to us @meekowave.
I have looked into your account and can see that there is an SNR issue in your area that is due to be fixed on Thursday 11th November at 3pm.
You might find that along with your Virgin Fibre, your Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this for you.
Regards,
Steven_L
