on 29-03-2023 10:49
I'm a bit new to home networking so I'm not 100% sure I'm understanding what I'm reading online.
Here's my setup and what I'm planning to do:
- I have gigabit fibre. My Hub 5 is downstairs in my living room, serving adequate Wi-Fi to all of downstairs, but signal is a bit crap upstairs
- I'm going to run a cat 6 cable from the router up through the ceiling to an upstairs bedroom, and connect that to a new wireless Access Point, which should be able to provide good Wi-Fi upstairs
Is this setup possible? Where the virgin hub is still providing Wi-Fi, as well as the Access Point? Or do I need to put the hub in modem mode to do this? If so, should I connect another Access Point to the hub to provide Wi-Fi downstairs?
Any advice/ideas much appreciated.
on 29-03-2023 11:02
Yes you can do exactly what you describe with the Hub 5 in Router mode i.e. ( Hub 5 < ---------- > WiFi AP )
We have a Hub 3 in Router mode with 2 TP-LINK WiFi APs attached it works well, plus the access points are fully under our control.
on 31-03-2023 12:09
Hey efficated, thank you for reaching out and a I am sorry to hear this.
Please can I just confirm if the above helped at all? Thanks
Matt - Forum Team
New around here?
