on 18-01-2022 18:11
Can you please advise if you can supply an adaptor to plug by landline phone (virgin) directly into my Hub 3 router.
This is due to the upcoming disconnection by BT of my landlines.
Robert McMillan
Customer acc no. [MOD EDIT: PERSONAL INFORMATION REMOVED]
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
on 19-01-2022 08:04
Hi Robert201,
Thanks for posting on the Community Forums!
I'm afraid that we do not supply the RJ11 adapters that are required to connect your landline handset to our hubs. I am sorry about this.
They can however, be purchased inexpensively online or from hardware shops.
Let us know if we can help with anything else.
Beth
20-01-2022 07:54 - edited 20-01-2022 08:01
@Beth_G wrote: ……I'm afraid that we do not supply the RJ11 adapters that are required to connect your landline handset to our hubs. I am sorry about this.They can however, be purchased inexpensively online or from hardware shops…….
OMG Now I’m really worried! A month or so before Xmas my POTS line lost dial tone and VM sent engineer with adaptor to enable 21CV connection to Hub3 instead:
unfortunately I had to return the engineer but I did get to retain the adapter f.o.c …. 😉
So where did he get the adapter if VM don’t supply them? Should I be worried he wasn’t an authenticated VM engineer even though his visible credentials appeared valid?
More seriously……
Maintaining telephony during power outages on 21CV is however far more problematic even if VM have fitted 21CV<>Hub battery backup as thIs is limited (apparently) to emergencY calls only! Completely unacceptable for at risk OAP’S/and clinically at risk users that could previously rely on inbuilt POT’s battery backup from local exchange mplex VM cabinet backup.
on 20-01-2022 08:38
Hi @Robert201
Thanks for the reply
Is the landline issue now resolved? Not to worry, the technicians we send are fully VM certified. ^Travis
