Volume not working on 360 remote
J_b86
Remote has been working fine since we got it in July. Tv on/off and channel up/down are working but volume won’t. Have tried the following:
Changed the remote’s batteries, re-paired by holding tv+0 for 10 seconds, did a factory reset by holding tv+rewind for 10 seconds and checked audio settings are set to tv & not a sound system. Also turned box off/on again. When in pairing mode, the volume doesn’t go up when I press ok as instructed. Have entered model of tv manually but still no luck.
Any other suggestions very welcome!
2 REPLIES 2
J_b86
Got the issue resolved. For anyone else who might have the same issue, what worked was just switching the HDMI port to a different one. Not sure why, but results are results!
Hi @J_b86
Thanks for posting on our community forum!
Great to hear the issue is now resolved, I hope you have a great day and be sure to contact us if you require any further assistance.
Travis_M
