on 28-07-2021 22:16
Greetings,
I am using my phone in Germany. Callers from Germany and the UK cannot hear me when they call me. I can hear them. If I call them, they can’t hear me.
I called the customer service and they asked me to record a voice note and see if I could hear it (which I could.) They didn’t hear me when they called me back 😞
They sent me the troubleshooter and I did everything described but still it doesn’t work. I got a message saying I might need a new SIM card. Does anyone have any advice? Thanks!
on 30-07-2021 09:14
Hi rosarioap,
Thank you for your post. I'm very sorry to hear about the issue you're having with your calls.
The message that advised you need a replacement SIM card, was that a text from ourselves?
^Martin
on 30-07-2021 10:57
Hi Martin,
No, that was the message I received when I did everything the troubleshooting instructions told me to do. Can you help me? Thanks!!!
on 30-07-2021 11:19
Thank you for that information.
In regards to the replacement SIM card. We can certainly work to order you a new one. But this would only be to a UK address.
When do you return to the UK?
^Martin
on 30-07-2021 12:15
Thank you Martin, that would be great. I return on August 6th. Would it be possible for you to send it to my home address so I can have it once I arrive? Thanks!!
on 30-07-2021 12:26
Thank you for that. What I will do is private message you so we can arrange this.
^Martin
