on 18-01-2022 10:43
Since last week there is a red light on my hub 3.0 I tried to reset it a few times but it's still the same.
on 18-01-2022 11:44
Hi DawidZaleski
Sorry to hear this
Redlight on the Hub will need us to replace it
In the mean time can you make sure its in a cool well ventilated place away from direct heat
I will need to send you a private message to pass security to arrange the swap
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 18-01-2022 13:42
Hi DawidZaleski
Thanks for those details
I have arranged for a replacement hub to be sent out
It can take 3-5 days and we will send you a tracking number
Gareth_L
