on 02-07-2022 20:44
on 03-07-2022 09:43
What do your router stats say, can you post them here for us? Someone should then be able to give you more advice on what to do next.
You can find them by going to your hub's web interface at http://192.168.0.1 in standard mode (try this first), or http://192.168.100.1 in modem mode, and clicking on "Check router status". There is no need to login.
Please post the info from all tabs - you may have to post them as separate replies here due to the size of the output.
on 03-07-2022 12:15
Thanks very much. last night I had a play about in the router settings. I disabled 2.4ghz and just kept 5ghz on. Also disabled channel optimisation. Now my speeds have gone from 10mb to 390mb download on virgin 350. And my uploads are perfect. Also latency on upload and download has gone from 500+ down to 10.
on 05-07-2022 14:29
Hi Wtf111111,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear you were having an issue but things have been resolved since making changes.
If you start to have an issue again, pop back and let us know and we can help further.
