on 24-08-2022 13:51
Need some help with this internet. It has not running properly for the last few days and also messing up with game consoles. I've rebooted the hub multiple times and also reset the hub as well as noticed a problem with it. I think the hub is faulty. Virgin media twitter sent me here so some help would be appreciated.
on 24-08-2022 15:22
on 24-08-2022 15:36
no issues in my area, i always check that first.
issues are on both wifi and cable. and static white light
on 24-08-2022 15:55
on 24-08-2022 16:42
I reset the box again and it hasn't sorted the console problem.
I have 4 tables for the downstream not sure which are needed.
25 | 331000000 | 6.5 | 38.6 | QAM256 | 25 |
1 | 139000000 | 7.2 | 37.6 | QAM256 | 1 |
2 | 147000000 | 7.3 | 37.4 | QAM256 | 2 |
3 | 155000000 | 7.2 | 39 | QAM256 | 3 |
4 | 163000000 | 6.7 | 38.6 | QAM256 | 4 |
5 | 171000000 | 6.4 | 38.6 | QAM256 | 5 |
6 | 179000000 | 6 | 39 | QAM256 | 6 |
7 | 187000000 | 6.1 | 38.6 | QAM256 | 7 |
8 | 195000000 | 5.8 | 39 | QAM256 | 8 |
9 | 203000000 | 5.5 | 38.6 | QAM256 | 9 |
10 | 211000000 | 4.9 | 38.6 | QAM256 | 10 |
11 | 219000000 | 4.4 | 38.6 | QAM256 | 11 |
12 | 227000000 | 4.3 | 38.6 | QAM256 | 12 |
13 | 235000000 | 4.6 | 37.6 | QAM256 | 13 |
14 | 243000000 | 4.9 | 38.6 | QAM256 | 14 |
15 | 251000000 | 4.9 | 38.6 | QAM256 | 15 |
16 | 259000000 | 4.8 | 37.6 | QAM256 | 16 |
17 | 267000000 | 4.6 | 38.6 | QAM256 | 17 |
18 | 275000000 | 6.1 | 38.6 | QAM256 | 18 |
19 | 283000000 | 6.9 | 38.6 | QAM256 | 19 |
20 | 291000000 | 7.2 | 38.6 | QAM256 | 20 |
21 | 299000000 | 7 | 38.6 | QAM256 | 21 |
22 | 307000000 | 6.8 | 39 | QAM256 | 22 |
23 | 315000000 | 6.4 | 39 | QAM256 | 23 |
24 | 323000000 | 6.4 | 38.6 | QAM256 | 24 |
26 | 339000000 | 6.8 | 38.6 | QAM256 | 26 |
27 | 347000000 | 6.9 | 39 | QAM256 | 27 |
28 | 355000000 | 6.8 | 39 | QAM256 | 28 |
29 | 363000000 | 6.6 | 39 | QAM256 | 29 |
30 | 371000000 | 6 | 38.6 | QAM256 | 30 |
31 | 379000000 | 4.6 | 39 | QAM256 | 31 |
25 | Locked | 38.605377 | 0 | 0 |
1 | Locked | 37.636276 | 0 | 0 |
2 | Locked | 37.355988 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.605377 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.605377 | 0 | 0 |
11 | Locked | 38.605377 | 0 | 0 |
12 | Locked | 38.605377 | 0 | 0 |
13 | Locked | 37.636276 | 0 | 0 |
14 | Locked | 38.605377 | 0 | 0 |
15 | Locked | 38.605377 | 0 | 0 |
16 | Locked | 37.636276 | 1 | 0 |
17 | Locked | 38.605377 | 1 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 8 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
33 | 96 | 4K | 1880 | QAM4096 | 759 |
33 | Locked | 40 | 3.2 | 2402867 | 17 |
on 24-08-2022 16:43
1 | 25800000 | 49 | 5120 KSym/sec | 64QAM | 4 |
2 | 46200000 | 50.8 | 5120 KSym/sec | 64QAM | 1 |
3 | 39400000 | 49.8 | 5120 KSym/sec | 64QAM | 2 |
4 | 32600000 | 49.3 | 5120 KSym/sec | 64QAM | 3 |
1 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
Thu 01/01/1970 00:01:27 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 24/08/2022 15:25:14 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 24-08-2022 16:50
on 24-08-2022 17:25
Here is the BQM -- https://www.thinkbroadband.com/broadband/monitoring/quality/share/1367b04dfb2d5d748a04821ec2f3c5e07d...
its not just the consoles but there is some times that internet will really slow down and there's a laptop that has been struggling to connect to WIFI at times. There has been a few times that the internet will go off during the night.
on 24-08-2022 18:21
on 24-08-2022 18:28
okay then
