on 04-08-2022 13:34
My internet has been disconnecting over the last 2 days about twice every 10 minutes then it'll be calm for a while and start again randomly. Can't play any games or I keep DC'ing - this happens on my PC as well as mobile devices.
on 04-08-2022 14:21
on 04-08-2022 14:51
I have a wifi extender - TP-LINK WPA4220 WiFi Powerline Adapter Kit - AV600 which is plugged through ethernet which is also going down
I have a Hub 3.0 model and the lights are a yellow colour but I have heard this is a LED colour problem which is acceptable, when resetting my hub all lights go Flashhing Green/Green then go back to yellow
on 04-08-2022 15:17
on 04-08-2022 15:30
Well i can't plug the pc into the router directly as they are in different parts of the house. I do believe the connection is dropping in and out. Either way when it does drop out all my devices connected even the ring drops out also
on 04-08-2022 15:37
on 04-08-2022 16:57
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a55a987fbbf60cda1b35c35f4eaa7f007a...
Please check if this is done correctly
on 04-08-2022 17:07
on 04-08-2022 17:18
1 | 266750000 | -12 | 34 | 256 qam | 17 |
2 | 138750000 | -14.4 | 33 | 256 qam | 1 |
3 | 146750000 | -14 | 33 | 256 qam | 2 |
4 | 154750000 | -14 | 33 | 256 qam | 3 |
5 | 162750000 | -13.5 | 33 | 256 qam | 4 |
6 | 170750000 | -13.4 | 33 | 256 qam | 5 |
7 | 178750000 | -13.2 | 34 | 256 qam | 6 |
8 | 186750000 | -12.7 | 34 | 256 qam | 7 |
9 | 194750000 | -12.7 | 34 | 256 qam | 8 |
10 | 202750000 | -12.7 | 34 | 256 qam | 9 |
11 | 210750000 | -12.7 | 34 | 256 qam | 10 |
12 | 218750000 | -13 | 34 | 256 qam | 11 |
13 | 226750000 | -13.4 | 33 | 256 qam | 12 |
14 | 234750000 | -13 | 34 | 256 qam | 13 |
15 | 242750000 | -13.2 | 34 | 256 qam | 14 |
16 | 250750000 | -13.2 | 34 | 256 qam | 15 |
17 | 258750000 | -12.5 | 34 | 256 qam | 16 |
18 | 274750000 | -12 | 34 | 256 qam | 18 |
19 | 282750000 | -11.5 | 35 | 256 qam | 19 |
20 | 290750000 | -11.2 | 35 | 256 qam | 20 |
21 | 298750000 | -10.7 | 35 | 256 qam | 21 |
22 | 306750000 | -10.7 | 35 | 256 qam | 22 |
23 | 314750000 | -10.5 | 35 | 256 qam | 23 |
24 | 322750000 | -10.4 | 35 | 256 qam | 24 |
1 | Locked | 34.9 | 15195822 | 23678 |
2 | Locked | 33.3 | 55789418 | 20851 |
3 | Locked | 33.4 | 50842892 | 22841 |
4 | Locked | 33.9 | 41576312 | 23891 |
5 | Locked | 33.9 | 45164319 | 35323 |
6 | Locked | 33.9 | 41340523 | 46544 |
7 | Locked | 34.3 | 37338387 | 40190 |
8 | Locked | 34.3 | 33449802 | 36023 |
9 | Locked | 34.9 | 30540878 | 40932 |
10 | Locked | 34.9 | 28457316 | 37555 |
11 | Locked | 34.4 | 27201650 | 40025 |
12 | Locked | 34.3 | 27098257 | 33358 |
13 | Locked | 33.9 | 26093609 | 32445 |
14 | Locked | 34.3 | 23469833 | 35084 |
15 | Locked | 34.3 | 22914649 | 33718 |
16 | Locked | 34.3 | 21941630 | 34299 |
17 | Locked | 34.4 | 17951681 | 31742 |
18 | Locked | 34.9 | 13926744 | 32532 |
19 | Locked | 35 | 12013779 | 31671 |
20 | Locked | 35 | 10245024 | 30113 |
21 | Locked | 35 | 9205595 | 31367 |
22 | Locked | 35.5 | 8284840 | 32933 |
23 | Locked | 35.5 | 7646463 | 30715 |
24 | Locked | 35.7 | 7125830 | 35225 |
1 | 39400000 | 43.3 | 5120 | 64 qam | 6 |
2 | 46200000 | 44 | 5120 | 64 qam | 5 |
3 | 25800000 | 42.3 | 5120 | 64 qam | 8 |
4 | 32600000 | 42.8 | 5120 | 64 qam | 7 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 04-08-2022 17:19
04/08/2022 17:13:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 17:13:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 17:13:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:37:43 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:37:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:36:53 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:36:53 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:36:52 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:36:52 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:31:55 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:31:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:30:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:30:59 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:23:39 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:23:39 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:01:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 16:01:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 15:58:33 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 15:58:33 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2022 15:58:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
