on 12-11-2021 15:43
Due to a blind spot in my upstairs office, I have an intelligent WiFi Pod plugged in on the landing. Recently, I've been having a problem where the light on the Pod goes green and I lose connection, with it becoming very patchy while the Laptop tries to connect to the Router downstairs.
It's not all of the time, but will happen for a good duration of time on a relatively frequent basis. It makes it impossible to have my work meetings.
How do I get this issue fixed?
on 28-10-2022 11:08
Hey @Madlad114,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your connection, are you able to move the pod closer to the hub to just check that the pod can connect to your hub?
Have you tried a pin hole reset of the hub since the issues started?
Lightning Fibre Ltd is a local server that the speed test would use to test your connection.
Kind Regards,
Steven_L
