on 19-05-2022 16:36
Hi, Sorry, but I read all of the other threads and still have an issue
My VM Hub 3 was installed yesterday. Initially I turned off wifi on the Hub 3 connected to my ASus which was in AP mode and everything worked fine.
I really wanted to use the Asus as the router as it seems more powerful/flexible than the VM Hub
I set the VMHub to Modem Mode. had ethernet from port 1 to the WAN port on my Asus (as it was before) . Left it a few minutes and then turned the Asus back to Router mode. I consistently got No Internet connected on the Asus config app and the LAN IP was showing as a local address (192.168.x.x) The WAN setting s were DHCP
Years ago when I last had VM, I had to spoof the MAC address of the VM router - is this still the case? Also should I be using Bridge Mode not Router mode on my Asus
For clarity, I have 2 ASUS XT8 and and XT4 in AirMesh config. Due to the house layout I have a 10metre Cat 6 between the VM Hub and the Asus XT8 - This works fine in the original config.
Should mention when I put the VM Hub in modem mode, I logged in via 192.168.100.1 and it showed that it was connected to the internet and Telephony OK, so the problem seems to be the connection to the Asus
Obviously something I am doing wrong - so looking for guidance please
Answered! Go to Answer
24-05-2022 16:18 - edited 24-05-2022 16:20
Connect only a PC to the hub change to modem mode wait a bit then power off the hub for 2mins when the hub starts up disable/enable the NIC on your PC or unplug replug the Ethernet till you get internet connect this PC to your Asus and login change it to router mode go to internet/WAN setting and use the MAC clone option to copy your PC MAC to Asus now connect the WAN port to the hub and it will work.
If not working get a new cable for the Asus to hub
on 24-05-2022 16:44
Thank you
on 26-05-2022 12:50
Finally working !!!!!
Initially the replacement hub was giving the same errors
As suggested, I tried a different ethernet cable between the Hub3 and my XT8 with no change
Fortunately someone else had mentioned using the MAC clone and it sprung into life.
I retested with my original ethernet and again no internet at my Asus XT8, which is really odd as that cable had been working fine when the Hub 3 was doing the routing and the Asus was in AP Mode
The joys of IP/Internet/routers etc !!!
05-04-2023 08:49 - edited 05-04-2023 08:54
John,
thanks for the FAQ, worked for me. I hope you don't mind but I thought some steps could be made a little more obvious:
This only needs to be done the first time you connect the router/Mesh to the VM hub
Once the Hub is running in Modem Only mode, and the router/Mesh network is online, the following IP addresses will be accessible from any browser inside your private network:
ASUS router/Mesh: 192.168.50.1
Virgin Media Hub: 192.168.100.1
