on 22-02-2022 21:43
Hi Just joined Virgin new customer and notice the hub I have been given is a hub 3 is that right ? I thought i would be given a newer hub this seems to be old equipment
Answered! Go to Answer
on 22-02-2022 21:53
@LornaDoo wrote:Hi Thanks for the reply, its broadband M200
Ok, the HUB 5 is still in trial, and the HUB 4 is usually provided on higher tier packages that require the revelevant tech the HUB 4 uses for the higher speeds.
on 22-02-2022 21:44
@LornaDoo wrote:Hi Just joined Virgin new customer and notice the hub I have been given is a hub 3 is that right ? I thought i would be given a newer hub this seems to be old equipment
What package are you on?
on 22-02-2022 21:47
on 22-02-2022 21:53
on 22-02-2022 22:00
on 23-02-2022 09:38
