on 27-01-2022 13:23
Dear Virgin Media,
We have just moved into our new home and the previous owner had your service installed (we do not sorry). We are quite concerned that the Virgin Media Wi-Fi service keeps showing up on our devices. We are quite concerned about this, can you please advise - after all the service should be terminated?
If the service has ended, then why is it showing up for us on all of our devices? Surely, this is not right...? I really would like some help here.
Regards,
James_Dunn
on 28-01-2022 17:00
on 28-01-2022 17:01
Hi There,
Sounds very logical - thank you very much indeed. Appreciated.
Cheers,
James
on 28-01-2022 19:15
@James_Dunn wrote:Hi Tudor,
Yes, I can see VM123456....for instance. This simply can't be right can it....?
P.S. Thank you very much for your time.
That is indeed a personal Wifi ssid. See if it disappears when turning the power off.
Or hunt around for a hub or plug in Wifi extender that could be broadcasting it.
