on 08-04-2023 10:07
Good morning, My virgin WiFi Hub 3.0 has got a constant orange light and our internet is working intermittently. I have tried a pinhole reset twice now but the light remains orange. Are there any tests that forum staff can run to check whether the router is working correctly. Thank you
Answered! Go to Answer
on 09-04-2023 00:15
on 08-04-2023 18:32
on 08-04-2023 20:26
Thank you for responding to my post. I did read other posts whereby in itself the orange light was of no real concern. Over the last couple of days I have lost internet for short periods, sometimes I couldn't get access to certain websites, this forum being one of them. This morning I logged into the router and rebooted it. This took an age (approx 20 minutes). I have run www.samknows.com and having run several speed tests shows consistently that the speed to my router is about 384 mbps but speed to my desktop which has line of site and is about 10 foot from the router has recorded between 4 mbps and the last test 15 minutes ago 43.7 mbps. I have just done the test with an ethernet cable between router and desktop which shows router download 384 mbps and desktop download 366 mbps. All devices in this household are usually connected via wifi. All is working as it should at the moment so I shall continue to monitor and see what happens.
on 08-04-2023 20:56
Further to my last post I have just tested my hub 3 on the VM website. It has showed to following info despite saying there were no problems in my postcode.
We’re looking into it. Check back here after 23 hours and if there’s still an issue we’ll help you book a technician.
on 09-04-2023 00:15
on 09-04-2023 20:49
I phoned VM first thing this morning. They told me I had to many devices connected to my router and I could upgrade my package to the M500 on a further 18 month contract. This was declined. We went through shutting down the router and various other checks and I was even offered a WIFI pod free for 1 month and then either send it back or pay £8 pounds a month. Since this morning my broadband has been stable so fingers crossed whatever the problem was has resolved itself.
on 10-04-2023 15:38
on 10-04-2023 20:09
Hi John, I did try the 0800 number which reported no faults in my area. It then referred me to the virgin media app. I thought I'd try the VM helpline as a last shot of the dice. That proved a waste of time. I have concluded that I shall move on at the end of my current contract to another ISP. Thank you for the advice you offered.
Dave
on 10-04-2023 21:14
