on 04-07-2022 13:31
Hi wondering if anyone can help. Currently have a hub 3 installed with m600 b/band with old style threaded isolator cable. Would I be able to use this old style isolator on the newer hub 4 with gig1 b/band. Or would I need to use the newer push connection style that is sent with the hub 4.
it’s just the newer style won’t be long enough and won’t fit in cable trunking that’s installed.
on 04-07-2022 14:34
No problem at all. The new push fit cables just go over the threads, but old style screw on ok.
