on 30-10-2021 15:20
Almost regularly, 2-3 times a day, my broadband modem would lose all internet connectivity for 4-5 minutes - both wired and wirelessly connected devices would not be able to access external IP addresses (internal traffic works fine, i.e I can ping one computer from another). After 5 minutes everything would be back to normal, speed test producing expected, high bandwidth results.
I've contacted support, they were apparently "seeing issues on their end as well", and supposedly opened a ticket. 2 days later I got a text confirming the "issue has been fixed", and that I should just restart my modem, which I did. However, this did not help, as the same thing continued to happen today.
FWIW, I have the Hub 4 and use it in "bridge" mode (i have my own wifi router).
Given the type of issue, I suspect it's either modem itself having some (power?) issues, or the local exchange box in my neighborhood, but my hands are tied and I don't know what to do next.
Can I ask for a modem replacement perhaps?
on 30-10-2021 18:09
on 30-10-2021 19:19
Thanks for the prompt reply John.I've set up the TB monitoring just now. At the moment it looks normal (which I think is expected as this happens only several times a day), but I'll continue monitoring.
The TB snapshot: https://www.thinkbroadband.com/broadband/monitoring/quality/share/bdd71d3c7afecdf20a2d87f9d64ddbccd2...
Other information you asked:
on 30-10-2021 19:20
Router Status > Status
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
Router Status > Downstream
25 | 330750000 | 3.1 | 38.6 | QAM256 | 25 |
1 | 138750000 | 8.3 | 39 | QAM256 | 1 |
2 | 146750000 | 8.3 | 40.4 | QAM256 | 2 |
3 | 154750000 | 8 | 40.4 | QAM256 | 3 |
4 | 162750000 | 7.3 | 40.4 | QAM256 | 4 |
5 | 170750000 | 6.9 | 40.4 | QAM256 | 5 |
6 | 178750000 | 6.5 | 40.4 | QAM256 | 6 |
7 | 186750000 | 6.4 | 40.4 | QAM256 | 7 |
8 | 194750000 | 6.1 | 40.9 | QAM256 | 8 |
9 | 202750000 | 5.8 | 40.4 | QAM256 | 9 |
10 | 210750000 | 5.8 | 40.4 | QAM256 | 10 |
11 | 218750000 | 5.7 | 40.4 | QAM256 | 11 |
12 | 226750000 | 5.7 | 39 | QAM256 | 12 |
13 | 234750000 | 5.6 | 40.4 | QAM256 | 13 |
14 | 242750000 | 5.5 | 38.6 | QAM256 | 14 |
15 | 250750000 | 5.5 | 39 | QAM256 | 15 |
16 | 258750000 | 5.5 | 39 | QAM256 | 16 |
17 | 266750000 | 5.4 | 39 | QAM256 | 17 |
18 | 274750000 | 5.2 | 38.6 | QAM256 | 18 |
19 | 282750000 | 5.2 | 39 | QAM256 | 19 |
20 | 290750000 | 5 | 39 | QAM256 | 20 |
21 | 298750000 | 4.6 | 40.4 | QAM256 | 21 |
22 | 306750000 | 3.9 | 39 | QAM256 | 22 |
23 | 314750000 | 3.4 | 39 | QAM256 | 23 |
24 | 322750000 | 3.1 | 38.6 | QAM256 | 24 |
26 | 338750000 | 3.1 | 39 | QAM256 | 26 |
27 | 346750000 | 3.2 | 39 | QAM256 | 27 |
28 | 354750000 | 3.1 | 39 | QAM256 | 28 |
29 | 362750000 | 3.1 | 39 | QAM256 | 29 |
30 | 370750000 | 3.1 | 38.6 | QAM256 | 30 |
31 | 378750000 | 3 | 39 | QAM256 | 31 |
25 | Locked | 38.605377 | 0 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 40.366287 | 9 | 0 |
3 | Locked | 40.366287 | 688 | 0 |
4 | Locked | 40.366287 | 22 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 7 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 893 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.605377 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
on 30-10-2021 19:20
33 | 94 | 4K | 1840 | QAM4096 | 424 |
33 | Locked | 40 | 2.5 | 31301903 | 0 |
Router Status > Upstream
1 | 46200000 | 36 | 5120 KSym/sec | 64QAM | 3 |
2 | 39400000 | 34.5 | 5120 KSym/sec | 64QAM | 4 |
3 | 60300000 | 36.3 | 5120 KSym/sec | 64QAM | 1 |
4 | 53700000 | 36.3 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 3146 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 3156 | 0 |
Router Status > Network log
<empty>
on 30-10-2021 19:22
Oops, sorry, I just realised you wanted a live chart, here it is: https://www.thinkbroadband.com/broadband/monitoring/quality/share/a0771b7bc017d940db0a943f741bf14f4b...
on 30-10-2021 19:31
on 30-10-2021 19:41
Hi John,
The "Networklog" does not show anything (other than an empty table).
There were also a bunch of "Pre RS Errors" in the Downstream section.
Would this warrant a visit from a Virgin engineer? Or perhaps a router replacement?
I dont really use any of the fancy Hub4 features, I just use it as a modem. Do you think I could perhaps replace it with something simpler that's perhaps less prone to breaking?
Thanks!
on 30-10-2021 19:53
on 30-10-2021 20:01
I stand corrected! 🙂 I got used to the term "bridge" elsewhere, but yes, it is running in "Modem" mode - I connect my own router to Eth1 port of the Hub4 and have Hub4 assign public IP via DHCP to my router's WAN port.
