on 07-11-2021 15:13
Afternoon, I have a hub 3. We've been getting intermittent WiFi drop outs for a couple of months now. It's usually 1 device at a time, so the rest still work. This ranges from smart phones, Alexa devices, Xbox etc. We've also had issues with streaming Netflix and Prime. The picture becomes distorted or simply stops quite frequently which should happen with a 200mb connection. I tethered my firestick to my phone yesterday when having issues trying to watch Prime and it worked fine. My son's Xbox cannot connect to the router, however can connect to my phone. I'm guessing there's an issue with the router broadcasting WiFi. I've done all the usual, reset router, reset devices etc. Any ideas?
on 07-11-2021 15:19
07-11-2021 15:35 - edited 07-11-2021 15:38
@legacy1 wrote:
Look at getting your own WiFi router with 1Gb ports and use the hub in modem mode....or you can go down the long path.
BEFORE doing that, it may just be a problem with the signal to the hub itself.
log into hub3 -
Here : 192.168.0.1 - DON'T SIGN IN, click - click router status [centre of screen] - and post the config figures - to see those press on the grey buttons/boxes labelled - configuration
You can also think about setting up a broadband quality monitor from think broadband.
(It's the little graph in my signature)
on 07-11-2021 19:23
Settings below. Tim
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt060-b.cm |
SFID | 3872 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 3871 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 07-11-2021 19:31
I already setup a monitor, most days look like this. Pretty sure the connection coming into the house is fine, it's the wifi in the house that's the issue. Thank you for your help by the way. Tim
on 07-11-2021 19:44
@timcymru1982 wrote:I already setup a monitor, most days look like this. Pretty sure the connection coming into the house is fine, it's the wifi in the house that's the issue. Thank you for your help by the way. Tim
It very well could be, and you can just go out and buy a big fat wifi6 router/mesh.
But I think it's worth checking this before you drop £200 for it.
Can you post all the stats from every tab please?
on 07-11-2021 20:34
Upstream Tab
1 | 53700174 | 38.8 | 5120 | 64 qam | 6 |
2 | 39399893 | 38.8 | 5120 | 64 qam | 8 |
3 | 46200081 | 38.8 | 5120 | 64 qam | 7 |
4 | 60300083 | 38.5 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 6 | 0 |
2 | ATDMA | 0 | 0 | 5 | 0 |
3 | ATDMA | 0 | 0 | 9 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
on 07-11-2021 20:35
Status Tab
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 53700174 | Locked |
Provisioning State | Online |
on 07-11-2021 20:36
Downstream Tab
1 | 203000000 | 6.9 | 38 | 256 qam | 9 |
2 | 211000000 | 7 | 40 | 256 qam | 10 |
3 | 219000000 | 7 | 40 | 256 qam | 11 |
4 | 227000000 | 6.9 | 38 | 256 qam | 12 |
5 | 235000000 | 6.6 | 38 | 256 qam | 13 |
6 | 243000000 | 6.5 | 38 | 256 qam | 14 |
7 | 251000000 | 6.4 | 38 | 256 qam | 15 |
8 | 259000000 | 6 | 40 | 256 qam | 16 |
9 | 267000000 | 6 | 40 | 256 qam | 17 |
10 | 275000000 | 5.9 | 38 | 256 qam | 18 |
11 | 283000000 | 5.8 | 38 | 256 qam | 19 |
12 | 291000000 | 5.8 | 38 | 256 qam | 20 |
13 | 299000000 | 5.9 | 38 | 256 qam | 21 |
14 | 307000000 | 5.6 | 38 | 256 qam | 22 |
15 | 315000000 | 5.5 | 38 | 256 qam | 23 |
16 | 323000000 | 5.6 | 38 | 256 qam | 24 |
17 | 331000000 | 5.5 | 38 | 256 qam | 25 |
18 | 339000000 | 5.5 | 38 | 256 qam | 26 |
19 | 347000000 | 5.5 | 38 | 256 qam | 27 |
20 | 355000000 | 5.3 | 38 | 256 qam | 28 |
21 | 363000000 | 5.5 | 38 | 256 qam | 29 |
22 | 371000000 | 5.5 | 38 | 256 qam | 30 |
23 | 379000000 | 5.3 | 38 | 256 qam | 31 |
24 | 387000000 | 5 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 9865 | 0 |
2 | Locked | 40.3 | 10036 | 0 |
3 | Locked | 40.9 | 11422 | 0 |
4 | Locked | 38.9 | 15499 | 0 |
5 | Locked | 38.9 | 17720 | 0 |
6 | Locked | 38.9 | 22007 | 0 |
7 | Locked | 38.9 | 25506 | 0 |
8 | Locked | 40.3 | 30143 | 0 |
9 | Locked | 40.3 | 32934 | 0 |
10 | Locked | 38.9 | 36826 | 0 |
11 | Locked | 38.9 | 42197 | 0 |
12 | Locked | 38.9 | 49968 | 0 |
13 | Locked | 38.9 | 57314 | 0 |
14 | Locked | 38.9 | 59914 | 0 |
15 | Locked | 38.6 | 74310 | 0 |
16 | Locked | 38.6 | 84566 | 0 |
17 | Locked | 38.9 | 106812 | 0 |
18 | Locked | 38.6 | 121279 | 0 |
19 | Locked | 38.9 | 142120 | 0 |
20 | Locked | 38.9 | 174293 | 0 |
21 | Locked | 38.6 | 179595 | 0 |
22 | Locked | 38.9 | 197266 | 0 |
23 | Locked | 38.6 | 229009 | 0 |
24 | Locked | 38.6 | 251442 | 0 |
on 07-11-2021 20:38
Network Log Tab
07/11/2021 15:09:15 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2021 10:21:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2021 06:56:30 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2021 03:08:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2021 18:56:30 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/10/2021 14:22:38 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/10/2021 11:24:59 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/10/2021 09:08:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/10/2021 03:12:20 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 21:25:50 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/10/2021 22:28:31 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/10/2021 07:03:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2021 21:40:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/10/2021 20:19:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/10/2021 14:52:47 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/10/2021 14:21:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/10/2021 12:40:34 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2021 12:57:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2021 08:02:25 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2021 08:02:13 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
