on 22-11-2021 20:15
Does anyone know when they will be offering the hub5 by sounds of it id be able to stop using Wi-Fi pods and would be amazing
on 22-11-2021 20:28
from what ive been able ascertain hub 5 is still in test stage and is only being offered as an invite to people on hub 3 have a look here
Virgin Media O2 UK Officially Launches HUB 5 Broadband Router UPDATE3 - ISPreview UK
on 22-11-2021 20:30
So again another lottery to see if u get one arghhh I’ll sit and wait hope they don’t take too much longer
on 22-11-2021 20:31
Just invest in your own kit. Worth it in the long run.
on 22-11-2021 20:33
Yea but which one I bought one previously they had nothing but issues and no idea what to get tbh
on 22-11-2021 20:35
@Anonymous wrote:Yea but which one I bought one previously they had nothing but issues and no idea what to get tbh
Very much depends on your circumstance.
Something like this as a starting point:
on 22-11-2021 20:37
Oh cool they look good so do we put the hub 3 into modem mode and go from there
on 22-11-2021 20:42
@Anonymous wrote:Oh cool they look good so do we put the hub 3 into modem mode and go from there
Correct.
The HUB goes into modem mode, one of the devices plugs into the HUB, the others connect wirelessly to the first device to extend the signal around your home.
on 22-11-2021 20:43
Ok is there anything link this with more than 1 extra Ethernet as I have few things that need to connect via Ethernet near the hub
22-11-2021 20:46 - edited 22-11-2021 20:48
@Anonymous wrote:Ok is there anything link this with more than 1 extra Ethernet as I have few things that need to connect via Ethernet near the hub
Each 'node' has two ethernet ports, however one will be required to connect the HUB to the closest node.
Something like the below will allow multiple devices to connect from the one spare ethernet port on the node:
https://www.amazon.co.uk/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B07PYSNSDD
Just make sure you have enough ethernet cables.
