on 09-09-2021 10:24
Hi guys and gals
I've setup the Hub 4 I have and changed the Wi-Fi network names to the name I wish to have, however I can see no way of changing the network identifier for the wired side see below:
I've tried switching the hub off and leaving it a while then switching it back on, but the network still identifies as the original name.
Am I missing something or will the physical network name always be this?
on 09-09-2021 10:26
on 12-09-2021 15:24
Hi @richie190784,
You can find out how to access the router's advance settings and the adjustments that you can make here.
on 12-09-2021 17:19
That’s the Hostname of the VM hub (IP address 192.168.0.1) and i don’t think it can be changed. Unable to check as I have always run in modem mode.
