on 28-01-2022 13:18
Hello
I've just been upgraded from my old VM Hub to a Hub 3.0. Previously there were areas of the house where Wi-Fi was poor and you would get buffering on any videos you were watching. This now seems to be significantly worse with the new hub, rooms downstairs where this was not previously a problem is now a problem.
I also noticed that when I tried to stream something on catch up last night it kept buffering and freezing, it never did that before. I was using Wi-Fi for the VM box downstairs but have now switched the Smart TV ethernet cable to the VM box and at least the TV is now ok.
However I was reading about Boosters, etc. and wondered whether these are worth considering, there seem to be mixed reviews on the internet and I'm unsure what the cost is?
Grateful for any help you may be able to provide.
Answered! Go to Answer
on 28-01-2022 15:13
on 28-01-2022 13:41
They do but I went for a new router instead as that will offer more advantages over boosters such as improved security, not needing to change any device config as you can set the router to the original SSID and password etc
I also found using one more plug behind the TV or wherever the current router may be was easier than sourcing another plug elsewhere that the kids, pets or partner could take out accidentally (or purposefully)
on 28-01-2022 15:13
