on 17-08-2021 13:36
Hi, since April connection cuts out very frequently. Over last few months this has been between every minute to every hour. It cuts out sometimes for a few seconds and hub light stays orange / pink and other times for a few minutes with hub light changing colour. Have a technician coming on Thursday after past two have been cancelled due to faults in the area which were subsequently fixed but didn't fix my issue.
Following guidance on this website and pasting link to broadband tracking started yesterday. Please can you provide me with any advice or fault identification would be good to get fixed.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/33c8bc39cf84e3b843cc34a6f847e5bfddd07ded-17-08-2021
on 17-08-2021 14:53
1 | 53700263 | 43.3 | 5120 | 64 qam | 2 |
2 | 46200000 | 43 | 5120 | 64 qam | 3 |
3 | 39400000 | 42.3 | 5120 | 64 qam | 4 |
4 | 60300059 | 43.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 17-08-2021 14:54
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt060-b.cm |
SFID | 250558 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 250557 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 17-08-2021 14:56
on 17-08-2021 14:57
Network Log v2
17/08/2021 13:33:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:33:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:33:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:25:31 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:25:30 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:25:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/08/2021 13:25:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 17-08-2021 15:07
Thanks, Lotharmat. Have phoned VM's helpline no. lots of times but they couldn't identify fault as shows as working at their side.
VM Engineer is booked for Thursday. Two previous engineer bookings have been cancelled by VM due to local service outtages being flagged and therefore engineer to visit my premises cancelled until local area issue fixed. On both occasions (post long delays in fixing issues with new deadlines provided many times), even when issues were "fixed" locally then my issues persist.
Just called number and said issue should be fixed by 18.45 today in local area. Will be a real shift in fortune if this latest area issue being fixed also fixes my issue. Just holding fingers crossed that VM don't cancel engineer again due to issue in the area or will reside in same catch 22 . Anything I should mention to engineer when / if they arrive that could help them to identify and solve issue from data provided?
Thank you for all the help!
Hoogie
on 17-08-2021 15:19
Just re-read your post, so SNR or noise ingress, will raise with technician when they visit (fingers crossed). Thanks for the help!
Hoogie
on 17-08-2021 15:26
on 19-08-2021 15:41
Hi @Hoogie1 thanks for posting and welcome to our community.
I am really sorry to hear that you've had ongoing connection issues. I have located your account from here and I would like to help resolve your issue. I am going to send you a private message.
Lee_R
