on 11-09-2022 22:08
A while ago i started having problems with the internet randomly going off or going to very slow speeds. I have the 350mbs package and it works fine until i play a game for a while and my computer does produce quite a lot of heat so I assume its heating up the room then the box. I moved it then it was fine. But recently my brother decided to take it apart and to see if he could fix it (He did not ask me aha) and when i looked at it after he did it i touched one of the heatsinks on the board and it was really hot to touch so I couldn't imagine what the actual chip underneath is like.
Would getting a replacement hub fix this because I'm just wondering if there's some sort of thermal compound that has gone or lost its effect overtime.
on 12-09-2022 14:52
on 12-09-2022 21:31
I have a hub 3.0 and its just the broadband as i dont use this one for sky sports or anything. This hub is dedicated to my computer and mobile devices in this area of the house as i dont get good wifi on our sky box. And it goes a amber colour every so often
on 13-09-2022 01:40
on 14-09-2022 00:26
Hey thank you for replying, its doing it right now and it does it on wifi and ethernet devices, the wifi devices just switch networks but my computer which is on ethernet will stay on. However if im in a call for example such as discord it will be fine then the ping will flicker from 30 to thousands and constantly do that, also does it on games so it just constantly jumping up and down and ive done a help diagnose and it says theres no issue which im confused about because there is 100% a issue of some sort
Thanks, Harry
on 14-09-2022 00:27
on 14-09-2022 01:47
on 15-09-2022 00:05
Acquired Downstream Channel (Hz) | 387000000 | Locked |
Ranged Upstream Channel (Hz) | 53700000 | Locked |
Provisioning State | Online |
1 | 387000000 | -1.9 | 40 | 256 qam | 32 |
2 | 203000000 | 0.2 | 38 | 256 qam | 9 |
3 | 211000000 | 0.5 | 38 | 256 qam | 10 |
4 | 219000000 | 0.5 | 36 | 256 qam | 11 |
5 | 227000000 | 0.7 | 36 | 256 qam | 12 |
6 | 235000000 | 1 | 38 | 256 qam | 13 |
7 | 243000000 | 1.4 | 38 | 256 qam | 14 |
8 | 251000000 | 1 | 38 | 256 qam | 15 |
9 | 259000000 | 1 | 40 | 256 qam | 16 |
10 | 267000000 | 0.7 | 38 | 256 qam | 17 |
11 | 275000000 | 0.5 | 38 | 256 qam | 18 |
12 | 283000000 | 0.5 | 38 | 256 qam | 19 |
13 | 291000000 | 0.7 | 38 | 256 qam | 20 |
14 | 299000000 | 0.7 | 40 | 256 qam | 21 |
15 | 307000000 | -0.2 | 38 | 256 qam | 22 |
16 | 315000000 | -0.7 | 38 | 256 qam | 23 |
17 | 323000000 | -0.5 | 38 | 256 qam | 24 |
18 | 331000000 | -0.7 | 38 | 256 qam | 25 |
19 | 339000000 | -0.9 | 38 | 256 qam | 26 |
20 | 347000000 | -1.2 | 38 | 256 qam | 27 |
21 | 355000000 | -1.5 | 38 | 256 qam | 28 |
22 | 363000000 | -1.5 | 38 | 256 qam | 29 |
23 | 371000000 | -1.2 | 40 | 256 qam | 30 |
24 | 379000000 | -1.2 | 38 | 256 qam | 31 |
1 | Locked | 40.9 | 57 | 239 |
2 | Locked | 38.9 | 184 | 14 |
3 | Locked | 38.9 | 172 | 11 |
4 | Locked | 36.3 | 627 | 28 |
5 | Locked | 36.6 | 532 | 31 |
6 | Locked | 38.9 | 467 | 0 |
7 | Locked | 38.9 | 257 | 0 |
8 | Locked | 38.6 | 136 | 0 |
9 | Locked | 40.3 | 142 | 0 |
10 | Locked | 38.9 | 131 | 0 |
11 | Locked | 38.9 | 159 | 0 |
12 | Locked | 38.9 | 155 | 0 |
13 | Locked | 38.9 | 222 | 0 |
14 | Locked | 40.3 | 106 | 0 |
15 | Locked | 38.9 | 116 | 0 |
16 | Locked | 38.9 | 133 | 0 |
17 | Locked | 38.9 | 103 | 0 |
18 | Locked | 38.9 | 139 | 0 |
19 | Locked | 38.9 | 130 | 0 |
20 | Locked | 38.9 | 141 | 0 |
21 | Locked | 38.9 | 85 | 0 |
22 | Locked | 38.9 | 119 | 0 |
23 | Locked | 40.3 | 59 | 0 |
24 | Locked | 38.9 | 88 | 2270 |
on 15-09-2022 00:07
1 | 53700000 | 54 | 5120 | 64 qam | 2 |
2 | 60300000 | 54 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 310 | 0 |
2 | ATDMA | 0 | 0 | 5 | 0 |
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | yewrkldJKDHSUBsgvca69834n |
SFID | 1218 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 1217 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 15-09-2022 00:07
14/09/2022 22:56:19 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 22:55:22 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 19:24:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 18:08:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 07:13:22 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 05:21:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 02:40:36 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/09/2022 02:40:36 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2022 18:38:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2022 18:38:57 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2022 18:38:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/09/2022 18:38:23 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
