on 10-04-2022 18:28
Ever since i upgraded to1Gbs its been nothing but trouble for me. Multiple engineers have been out an looked at the line checked all the line into my property there saying everything is fine but the high jitter an packet loss just never seems to go away.
They found that the level where high on the download channels that was fixed the connection went better for a little while that stopped my router disconnecting. but the overall connection is still not the best. i cant game online without getting rubber banding due to packet loss an high jitter.
I have cat6 ethernet cable. directly to my 1Gbs network lan card from the Hub 4.
I'm starting to think the real issue are these terrible hub 4's...
using samknows i get 1.7 jitter then to pc its showing 3.8 jitter how does it go that high just from going through the hub 4 to the pc makes no sense at all. even 1.7 jitter to the hub is back enough that should not be that high either.
i have also monitored the line with thinkbroadband monitor an can see im getting latency spikes all the time an packet loss. something needs to be done about it now its getting a joke.
on 10-04-2022 18:29
25 | 331000000 | 3.5 | 39 | QAM256 | 25 |
1 | 139000000 | 7.6 | 39 | QAM256 | 1 |
2 | 147000000 | 7.5 | 38.6 | QAM256 | 2 |
3 | 155000000 | 7.2 | 40.4 | QAM256 | 3 |
4 | 163000000 | 6.7 | 40.4 | QAM256 | 4 |
5 | 171000000 | 6.4 | 40.4 | QAM256 | 5 |
6 | 179000000 | 6.1 | 39 | QAM256 | 6 |
7 | 187000000 | 5.8 | 39 | QAM256 | 7 |
8 | 195000000 | 5.5 | 39 | QAM256 | 8 |
9 | 203000000 | 5.7 | 39 | QAM256 | 9 |
10 | 211000000 | 5.4 | 39 | QAM256 | 10 |
11 | 219000000 | 4.9 | 39 | QAM256 | 11 |
12 | 227000000 | 5.2 | 40.4 | QAM256 | 12 |
13 | 235000000 | 5.1 | 40.4 | QAM256 | 13 |
14 | 243000000 | 4.4 | 39 | QAM256 | 14 |
15 | 251000000 | 4.8 | 38.6 | QAM256 | 15 |
16 | 259000000 | 5 | 38.6 | QAM256 | 16 |
17 | 267000000 | 4.1 | 39 | QAM256 | 17 |
18 | 275000000 | 3.7 | 39 | QAM256 | 18 |
19 | 283000000 | 3 | 38.6 | QAM256 | 19 |
20 | 291000000 | 2.7 | 38.6 | QAM256 | 20 |
21 | 299000000 | 3.3 | 38.6 | QAM256 | 21 |
22 | 307000000 | 3.8 | 39 | QAM256 | 22 |
23 | 315000000 | 3.5 | 39 | QAM256 | 23 |
24 | 323000000 | 3.3 | 38.6 | QAM256 | 24 |
26 | 339000000 | 3.6 | 39 | QAM256 | 26 |
27 | 347000000 | 3.6 | 39 | QAM256 | 27 |
28 | 355000000 | 3.6 | 39 | QAM256 | 28 |
29 | 363000000 | 3.7 | 39 | QAM256 | 29 |
30 | 371000000 | 3.5 | 39 | QAM256 | 30 |
31 | 379000000 | 3.5 | 39 | QAM256 | 31 |
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.605377 | 0 | 0 |
3 | Locked | 40.366287 | 1 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.605377 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 39 | -2.3 | 185381179 | 0 |
on 10-04-2022 18:29
1 | 60300000 | 47.5 | 5120 KSym/sec | 64QAM | 9 |
2 | 39400000 | 45.8 | 5120 KSym/sec | 64QAM | 12 |
3 | 46200000 | 45.8 | 5120 KSym/sec | 64QAM | 11 |
4 | 53700000 | 46.8 | 5120 KSym/sec | 64QAM | 10 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 10-04-2022 19:18
Stats look okay to me. BQM seems to be reflecting a wider issue at VM this weekend.
Maybe try swapping the ethernet cable and /or the hub port.
on 11-04-2022 01:04
Just goes to show that router mode in the hub does not make your connection lower jitter then if you use modem mode and your own router
on 18-04-2022 01:16
Its just terrible line quality
on 20-04-2022 08:46
Hi @butchydutchy,
Thank you for your posts and welcome back to our community forums. We're here to help.
I'm very sorry to hear you've been facing some connection issues recently. I've checked our systems and I can't currently see any issues on the line to explain these faults you're experiencing with your connection. Are these problems ongoing for you today?
If they are, can you share with us a live BQM so that we can see what's going on with your connection in real-time?
on 25-04-2022 20:02
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f238dc87e1c8b8413ccb7e8fe1a93b55f4...
This is the live graph cheers.
An here are some previous days.
I see a lot peak our congestion which is just unacceptable to be honest its clearly over selling if it cant handle peak hour. i cant play games during these times at all its unplayable..
also the constant spikes even when the network is idle not being used is strange. i get them spikes client end also again i could be playing a game an it just spikes up to 150ms ping completely random.
25-04-2022 20:26 - edited 25-04-2022 20:29
Thats not congestion.
The 'humps' are a problem effecting the entire network that virgin are dragging their feet on.
Eventually they will pull their finger out and fix it.
The spikes every single hour I believe are automated speed tests to the router conducted by virgin. This allows them to so how an area is performing.
I also got them and I also complained, they completely ignored me and the issue. I never even got an 100% answer to what it actually was but I believe that I'm probably correct. I also remember them saying that if the line is in use the test cancels it's self as to not effect performance. Yet again they failed realize that actually it does effect gaming. The effect of having a momentary spike in latency.
The way I got rid of the hourly spikes was to buy my own router and place the hub in modem mode.
Not exactly a great solution, but it worked.
on 25-04-2022 22:01
@risc19Snip…
…snip
You hope…..
