cennon
Tivo connected to a monitor
Hello I use my 4k monitor to watch tv on and when I put my TiVo box into standby it used to turn my monitor off but I think there was some sort of update to the TiVo box so now I need to turn the power off to the monitor or unplug the hdml cable from the TiVo box is there some setting im missing to get it back to how it was or because of some update I now need to manually turn monitor off even if I put TiVo to stand by and turn computer on I need to manually tell monitor to look for the dp socket on it any help would be great and thanks
Cennon
  • 9.22K
  • 380
  • 638
Re: Tivo connected to a monitor
Hi cennon,
Welcome to the community.
I have been having a look into this regarding the update and I have found out that currently we're unable to restore the previous setup prior the update.  At the moment there isn't a time frame that we can offer to change this.  It may be worth exploring the power saving settings to see if this helps.
If anything changes or there's an update we shall let you know.
Collette.
cennon
ok thanks for the info
