mrpazz74
V6 box and Samsung smart remote
can anyone help please, have just bought latest Samsung tv model UE50R7400 with latest smart remote rmcspr1ap1, I cannot link it up to the v6 box.Have been in touch with Samsung tech. dep. they suggest there is a problem with the v6 settings.
Sorry if ive rambled  please fogive as its my first post.
  • 1.02K
  • 144
  • 217
DJ_Shadow1966
Knows their stuff
Re: V6 box and Samsung smart remote
Hello
This may be the answer you are looking for, if you have the V6 box with the V6 remote (dual Radio Wireless and InfraRed) then this combination if not Infra Red but is Radio Wireless, so you may have to unpair the V6 remote from V6 Box.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
mrpazz74
Thankyou will give it a try and let you know how I get on.
  • 4.63K
  • 312
  • 775
Roger_Gooner
Superstar
Surely you should be pairing the V6 remote with the TV to control volume.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
