on 10-01-2022 16:29
I have just arrived in Ireland, I can make outgoing calls but when my phone rings and I answer I am not connected to the caller in the uk although the call timer shows I am connected. I have data roaming turned on and I have used thisphone in Ireland before with no problems.
on 20-11-2022 18:01
Hi Joanne, thanks for the message and sorry to hear that you are not receiving calls abroad.
I will send you a private message so that this can be looked into further.
Kind regards, Chris.
on 21-11-2022 11:45
Hi Joanne
Basically there is no solution yet and no sign of one anytime soon either. Only Monday of last week, Martin from the Forum Team said on another forum string for exactly the same issue that you're experiencing:
Monday
We can certainly appreciate your frustration with this ongoing issue. We are still investigating this and working to have it resolved as soon as possible.
^Martin
I see Chris_W1 has responded to your post...they have all clearly been briefed to go through the same processes. He'll PM you, ask lots of security questions, task you with checking lots of settings, probably offer a replacement SIM card, none of which will make any difference whatsoever as has been reported many times on other strings. Nobody will admit what the issue is, but I suspect it is far more fundamental and likely costly which is why I don't believe it is been investigated/solved with any vigour. Customers are being fobbed off with 'We are still investigating this and working to have it resolved as soon as possible.'. Yes, a number of customers will leave them because of this issue, but that's probably cheaper than fixing it. Otherwise why wouldn't they give some kind of explanation that we can understand – when asked for one, I'm just met with a blank response.
Good luck
on 21-11-2022 11:59
HI stevenmdavidson, thanks for the message and sorry to hear that you are having issues with the calls.
Has Martin been able to get everything resolved for you.
Kind regards Chris
on 21-11-2022 12:02
Many thanks for all this info Steve.
It is very frustrating as I too keep getting fobbed off with the same response.
@Virgin - Can someone please respond to this thread and all the others with a detailed response as to what you are actually doing to resolve this fundamental inability to provide the service you had said you would provide in my contract.
It is clear that you are in breach of contract by not providing the service that I signed up to.
I have raised this problem numerous times and am still no further along with a resolution. I am paying to be able to use my mobile whilst in Ireland and you are not able to fulfill your obligation.
Looking forward to hearing from you.
Many thanks
Joanne
on 21-11-2022 12:04
Hi Chris_W1
Surely you're joking...have you even read my post? Does 'We are still investigating this and working to have it resolved as soon as possible.' sound like the issue has been resolved? Are you a Bot or human?
on 21-11-2022 12:10
Hi Joanne
I tried emailing this to Jon Fawcett Head of Mobile Product at Virgin Media last week but it bounced back on [MOD EDIT: Removed] and I haven't had time or inclination to try other variations of the email address. There's also Jeanie York Chief Technology Officer at Virgin Media O2 of anyone has email addresses, maybe they can shed light on the problem and reply sensibly to their customers.
Hi Jon Fawcett
on 21-11-2022 12:22
Hi Steve
Many thanks for all this info.
@Virgin Can someone reply with the name and email address of the Head of Mobile Product and also the name and email address of the Chief Technology Officer please so I can contact them directly.
I imagine many other customers will also be grateful for these contact details to express their frustration with this ongoing saga that seems to bounce from one team member to another with no ownership taken that there is a fundamental flaw in the technology.
Many thanks
Joanne
on 21-11-2022 12:30
Hi Joannemitchell, thanks for the reply.
Would you be able to reply to the private message so that this can be looked into further?
on 21-11-2022 16:22
Hi Joanne
If you manage to get anywhere, can you please post on this string and/or the strings below which also relate to the same problem:
Can't hear international calls
No service abroad
All the best
Steve
on 22-11-2022 17:21
Hi Joannemitchell, thanks for the message.
We have not received your reply to the PM yet, please reply at your earliest convenience
