Yam1065
  • 9
Message 1 of 17
slow connection
when we upgraded from M100 to M500 we barely make 200Mbps with a wired connection, Virgin say there are no outages in our area, i have tried all they have advised including a new ethernet cable and pin hole resets,the router is not in modem mode.There are no loose connections.Any ideas?
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 2 of 17
Re: slow connection
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Disconnect all other Ethernet cables when running the test
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
Yam1065
  • 9
Message 3 of 17
Re: slow connection
just done the test and...latency 19.5ms jitter 3.50ms Download 169Mbps and upload 38.7Mbps
using a cat 6 cable.
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 4 of 17
Re: slow connection
Can you please upload your router stats and set up a BQM
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
DO NOT LOG IN, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
Yam1065
  • 9
Message 5 of 17
slow connection
Hi there anybody tell me if this is good or bad?
Yam1065
  • 9
Message 6 of 17
slow connection
https://www.thinkbroadband.com/broadband/monitoring/quality/share/569061d1a4e82b192e3078eb0ed6355db27c647e-17-04-2021
 Hi could somebody have a look at this and tell me if its good or bad please.
SCA1972
  • 6.13K
  • 673
  • 2.14K
Message 7 of 17
Re: slow connection
@Yam1065 Please don't create multiple threads for the same issue, it is against the forum rules.  I have merged your threads.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 8 of 17
Re: slow connection
Looks ok mate 🙂
Zak_M
  • 6.12K
  • 315
  • 544
Message 9 of 17
Re: slow connection
Good morning @Yam1065
As advise by @conman33158 please could you upload your router stats?
Kind regards,
Zak_M
Yam1065
  • 9
Message 10 of 17
Re: slow connection
Hi will do later as i am at work atm 👍
