gilgongo
  • 50
Dialled in
Message 1 of 16
Will A 3rd Party Router Help My Weird Network Issues?
For ages, I've been puzzled by things seem get confused or perform badly on my network. Poor/fluctuating ping times mainly, but also other stuff not related to speed, which is always reported to be good (I'm in North London BTW).
I also have a SuperHub 2, because when I first joined Virgin there was some incredibly weird problem with the SH3 and the model of my exchange hardware which meant that it kept cutting out so I had to downgrade. That was several years ago though.
Recently, I've been using this application which enables musicians to play together remotely in real time. It seems like my setup is probably responsible for a fair amount of latency.
Can anyone advise whether getting a 3rd party router might help?
Here's an overview of what I have and what I'm thinking of doing.
If that looks like a good idea, does anyone have any recommendations for a good router to use? Something like this or this perhaps?
Thanks for any help.
Kippies
  • 12.44K
  • 859
  • 3.22K
Message 2 of 16
Re: Will A 3rd Party Router Help My Weird Network Issues?
IS it a SHUB2 or SHUB2AC?
gilgongo
  • 50
Dialled in
Message 3 of 16
It's a 2AC - just looked at its bum.
PS: Holy Hell!
Roger_Gooner
  • 6.73K
  • 490
  • 1.19K
Legend
Message 4 of 16
Forget about the router as it cannot help if your problems are to do with your hub or access network.
Can you post some stats. Go to 192.168.0.1, copy and paste the Downstream, Upstream and Network Logs. Mask any public IP address.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
gilgongo
  • 50
Dialled in
Message 5 of 16
OK here's the downstream channels:
Locked1138750000 Hz256 QAM0.8 dBmV 37.9 dB19327283
Locked2146750000 Hz256 QAM0.6 dBmV 38.3 dB14054284
Locked3154750000 Hz256 QAM0.3 dBmV 38.3 dB696292
Locked4162750000 Hz256 QAM0.1 dBmV 38.3 dB445302
Locked5170750000 Hz256 QAM-0.4 dBmV 38.3 dB292289
Locked6178750000 Hz256 QAM-0.6 dBmV 39.0 dB283275
Locked7186750000 Hz256 QAM-0.8 dBmV 38.3 dB286284
Locked8194750000 Hz256 QAM-1.1 dBmV 38.3 dB280279
Upstream:
Locked8053700000 HzATDMA49.8 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked7960300000 HzATDMA50.0 dBmV64QAM6400000 Hz5120 Ksym/sec
NotLocked00 Hz 0 dBmV  0 Ksym/sec
Network log:
18/04/202016:18:43 GMT66050310Auth Success - Web login successful.
18/04/202016:18:37 GMT66050310Auth Success - Web login successful.
18/04/202013:30:10 GMT66050310Auth Success - Web login successful.
18/04/202013:30:03 GMT66050310Auth Success - Web login successful.
18/04/202010:07:17 GMT66050310Auth Success - Web login successful.
15/04/202013:46:36 GMT68010302DHCP WAN IP - 82.x.x.x
15/04/202013:45:52 GMT68000407TOD established
15/04/202013:45:40 GMT84000510Downstream Locked Successfully
15/04/202013:45:32 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
15/04/202013:45:20 GMT82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
15/04/202013:41:47 GMT84020200Lost MDD Timeout
15/04/202013:41:46 GMT84020200Lost MDD Timeout
15/04/202013:41:42 GMT84000500SYNC Timing Synchronization failure - Loss of Sync
15/04/202013:41:41 GMT84000500SYNC Timing Synchronization failure - Loss of Sync
15/04/202013:31:06 GMT68010302DHCP WAN IP - 82.x.x.x
Roger_Gooner
  • 6.73K
  • 490
  • 1.19K
Legend
Message 6 of 16
You certainly had network lock failures on Wednesday, and I'd rather not see any Post RS errors or the somewhat high upstream power levels. Can you reboot your hub and post your stats and logs after a day. Also, what are your speeds with a wired connection using speedtest.net.
gilgongo
  • 50
Dialled in
Message 7 of 16
OK thanks - will reboot and post tomorrow.
Meanwhile, I'm getting the following from speedtest.net this evening (before reboot):
PING ms 9
DOWNLOAD Mbps 111.60
UPLOAD Mbps 10.07
Doesn't seem too bad right now in fact.
gilgongo
  • 50
Dialled in
Message 8 of 16
So here's the downstream channels a day after reboot:
Locked1138750000 Hz256 QAM0.9 dBmV 38.3 dB5948271
Locked2146750000 Hz256 QAM0.7 dBmV 38.3 dB4225303
Locked3154750000 Hz256 QAM0.5 dBmV 38.3 dB422298
Locked4162750000 Hz256 QAM0.3 dBmV 38.3 dB324280
Locked5170750000 Hz256 QAM-0.2 dBmV 38.3 dB309295
Locked6178750000 Hz256 QAM-0.4 dBmV 38.6 dB315310
Locked7186750000 Hz256 QAM-0.6 dBmV 38.3 dB302297
Locked8194750000 Hz256 QAM-0.9 dBmV 38.3 dB309297
Upstream:
Locked8053700000 HzATDMA49.3 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked7960300000 HzATDMA49.5 dBmV64QAM6400000 Hz5120 Ksym/sec
0 Ksym/sec
Network log:
19/04/202019:21:51 GMT66050310Auth Success - Web login successful.
19/04/202019:21:44 GMT66050310Auth Success - Web login successful.
19/04/202010:43:57 GMT66050310Auth Success - Web login successful.
18/04/202021:24:26 GMT68010302DHCP WAN IP - 82.x.x.x
18/04/202021:23:32 GMT68000407TOD established
Time Not EstablishedTime Not Established84000510Downstream Locked Successfully
18/04/202021:14:33 GMT66050310Auth Success - Web login successful.
18/04/202021:14:27 GMT66050310Auth Success - Web login successful.
Roger_Gooner
  • 6.73K
  • 490
  • 1.19K
Legend
Message 9 of 16
What speeds are you now getting?
gilgongo
  • 50
Dialled in
Message 10 of 16
Speeds I'm now getting are
PING ms 10
DOWNLOAD Mbps 105.57
UPLOAD Mbps 10.03
However speed and ping times aren't the whole story with the performance issues I'm having. For example, one Virgin user I've seen has said they got better performance out of the app I've been using when they turned off "Block Fragmented IP Packets" - but that seems to be a SuperHub 3 thing. I get strange UDP failures to contact hosts and whatnot. Almost like some kinds of network activity are being throttled in some way.
