doublet
Message 1 of 5
What speed should I expect?
When I subscribed to the M100 Fibre Broadband service I was led to believe I should expect a download speed of about 108Mbps however I've never seen this speed when checking. Normally speedtest.net reports between 70-80Mbps. All testing is done on a Windows 10 PC using ethernet cat5 cabling.
Your advice would be appreciated.
  • 10.12K
  • 748
  • 2.11K
Message 2 of 5
Re: What speed should I expect?
Does your PC have a 10/100 Ethernet port because that's the sort of speed I'd expect if you didn't have a 100/1000 port
Click to learn more about VIP
Use Kudos to say thanks
  • 13.11K
  • 1K
  • 3.04K
Message 3 of 5
could also be the cat5 cable - you would be better with cat5e or better
____________________
Tony
doublet
Message 4 of 5
Okay I've checked and tested my cabling which is all cat5e. My PC has a gigabit connection to a Netgear GS108 switch. The Hub will only connect to the switch at 100 Mbps which seems to be the problem. I was previously with BT and their smart hub had no problems with the gigabit connection.
  • 9.04K
  • 930
  • 1.41K
Message 5 of 5
take the switch out of the equation and test the pc wired directly to the Hub
