  • 58
  • 13
Gary333
Dialled in
Message 41 of 98
Re: Speed and latency problems
 Same problems here. Performance is terrible!
Today
08952a2757689d5af4c1d8837df33211b88e4155-14-10-2018
13th Oct
1a452a4ce9a585a9c9f0a5475540abe8412e68b0-13-10-2018
12th Oct
2d94425c602a49f5793f7f048389e8395a6d7a08-11-10-2018
11th Oct
dd6662f7abc70fa105f2f804e7ee3acf7df7aa6e-10-10-2018
  • 105
  • 7
rockies
Dialled in
Message 42 of 98
Your graphs are not showing up
  • 524
  • 67
aceado
Fibre optic
Message 43 of 98
this is by far the worst i've seen so far!
ddf589d49ce038dd6b08d7cccc5d4220a9d97e3a-14-10-201814/10
a7597f741215b16e2bd124d0f4fbed6e096d9f26-14-10-2018
___________________________________________
i might be harsh but i will get to the point unlike some!
internet: 350/20 area: 014 status: suffering from weird peak issues.
at virgin we like to fob you off with little as possible!
  • 19
MSCU990
Message 44 of 98
@aceado - I'm having exactly the same problems as you. I'm in Doncaster in area 14, called customer services a month or so ago who advised there were no issues.
Most nights, roughly between 5pm - midnight, my speeds drop massively. I have Vivid 350 and between those hours I regularly get as low as 6Mbps, but regularly get over 350Mbps outside of those hours.
@Virgin - Do you know what the problem is and when we can expect it to be resolved?
  • 58
  • 13
Gary333
Dialled in
Message 45 of 98
Even worse today. Virgin what is going on?
Today
25bd34df8710fbd49d81e040cd0d497223c09692-15-10-2018
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
  1     3 ms     2 ms     2 ms  192.168.0.1
  2    11 ms    10 ms    11 ms  10.187.16.1
  3    39 ms    40 ms    37 ms  brad-core-2a-xe-020-0.network.virginmedia.net [82.2.241.89]
  4     *        *        *     Request timed out.
  5    47 ms     *       48 ms  86.85-254-62.static.virginmediabusiness.co.uk [62.254.85.86]
  6    56 ms    47 ms    46 ms  ldn-b1-link.telia.net [213.248.84.25]
  7    48 ms    46 ms    48 ms  ldn-bb4-link.telia.net [62.115.143.26]
  8    49 ms    45 ms    47 ms  ldn-b5-link.telia.net [213.155.132.197]
  9     *        *        *     Request timed out.
 10    48 ms    59 ms    47 ms  151.101.0.81
 Edited post with VPN turned off so VM can see my true IP address if needed. Above traceroot was done without VPN active (as browser only)
  • 524
  • 67
aceado
Fibre optic
Message 46 of 98
next time do a tracert 80.249.99.164 but it sure seems like both brad-core-2a and brad-core-2b are having issues which need to be fixed
  • 58
  • 13
Gary333
Dialled in
Message 47 of 98
I've just run the traceroute to that IP.
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
1 4 ms 5 ms 3 ms 192.168.0.1
2 21 ms 13 ms 16 ms 10.187.16.1
3 16 ms 14 ms 12 ms brad-core-2b-xe-020-0.network.virginmedia.net [82.2.241.113]
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 49 ms 46 ms 55 ms eislou2-ic-2-ae0-0.network.virginmedia.net [62.254.84.62]
9 48 ms 43 ms 44 ms linx-gw2.thdo.ncuk.net [195.66.236.240]
10 58 ms 49 ms 45 ms po4-31.core-rs2.thdo.ncuk.net [80.249.97.85]
11 48 ms 50 ms 41 ms pingbox1.thinkbroadband.com [80.249.99.164]
Are you still seeing massive speed reductions. Even now on Virgin Nottingham server i am <20mb/s. On every other server it's 2-8mb/s
  • 524
  • 67
aceado
Fibre optic
Message 48 of 98
yes also seeing the same slow speed issue like your seeing
  • 105
  • 7
rockies
Dialled in
Message 49 of 98
Slow here again. Also had an engineer out who couldn’t find any problem on my connection but he did speak someone on the phone. He said he was passing my details to someone and they would call back and monitor the connection. Also showed him this topic on the forum. By any chance are you all in the Wheatley area of Doncaster?
  • 524
  • 67
aceado
Fibre optic
Message 50 of 98
the issue isn't local to where we live it's more the issue where we're getting the main internet feed from which is somewhere in bradford and that's where the problem is and needs to be fixed if I was to guess most likely a network/interface problem which needs to be found and fixed
