flintstone61
Message 1 of 8
Capping
I pay for a speed of 350, but for a while now have been getting a speed of around 160. A while back when I got to speak to an actual human when the same happened, it appeared that a magic button was pressed and my speed went right up again for about a month.
Is there a magic button, and could my speed have been capped?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Capping
Speeds aren't capped.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
flintstone61
Message 3 of 8
Re: Capping
sorry, tried this but too complicated for me..
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
Re: Capping
I specifically wrote the instructions for people that don't use English as their first language to a UK educational level of year 5 (10 to 11 Year olds).
If it is truly too difficult maybe get someone to help you ?
flintstone61
Message 5 of 8
Re: Capping
well if I was a 10-11 year old with English not my first language I am sure I would be fine, and not feel quite as patronised as I feel right now. I shall seek help elsewhere.
Emma_C
  • 8.28K
  • 512
  • 559
Message 6 of 8
Re: Capping
Hi Flinstone61,
Really sorry that you're not getting the speeds you expected and you've been unable to try the above suggestions by MikeRobbo. If you do get a second to try and work through it, it's worth doing.
In the meantime I've tried to have a look at the back end of your account but I've been unable to locate it.
If you're still having issues please can you pop me a personal message with your address on so I can take a look at things?
Emma_C - Forum Team
flintstone61
Message 7 of 8
Re: Capping
Thank you Emma. Virgin sent me a new modem. Problem solved!
Emma_C
  • 8.28K
  • 512
  • 559
Message 8 of 8
Re: Capping
Ah great news.
Do let us know if you need anything else 🙂
Emma_C - Forum Team
