on 15-05-2023 14:27
Hi, I am wondering if the VM socket of my flat as in the attached photo works out for a fibre connection.
The availability checker said yes in my post code area, but I just want to make it sure.
Many thanks.
Answered! Go to Answer
on 15-05-2023 16:36
Hi @chovin ,
Thank you for reaching out to us here, its great that you are considering joining us.
The socket you have shared is definitely ours and should not give you a problem at all, it is one of our newer ones so should be good to go. I will send you a private message for some extra details and triple check this for you but i am sure it should be fine.
Thank you
Jon
on 15-05-2023 16:36
Hi @chovin ,
Thank you
Jon
on 17-05-2023 16:47
Hi @chovin 👋 Thank you for your post and welcome to the Virgin Media Community 😀
Have you received and responded to the private message sent by my colleague?
Regards,
Daniel
